Hey guys I just purchased and downloaded Forza H 3 and I have one minor issue. The game will load the playground games intro as well as the Turn 10 and Microsoft studio intro (mind you in real bad quality) but as soon as Microsoft studio gets off the screen I get a crash back to the desktop.
I have turned off the microphone in settings and reset the game as well as updated my video drivers. What am I missing?? I have just set up my racing sim and I am dying to drive it!
Thanks guys and Merry Christmas/Boxing day
https://linustechtips.com/topic/711971-forza-horizon-3-help/
I'm having trouble deciding if pun was intentional or not.
Can you post your system specs?
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/711971-forza-horizon-3-help/#findComment-9086016
You're dying to drive it! Drive as in get it to run! No? Never mind...
Have you verified the game files through Steam? Have you done a Google search for similar issues?
https://linustechtips.com/topic/711971-forza-horizon-3-help/#findComment-9086045
Can you reinstall the game to a different drive? Have you tried to restart? Did you try to run the game borderless or windowed?
https://linustechtips.com/topic/711971-forza-horizon-3-help/#findComment-9086088
Can you run the game? As soon as it loads press "Alt + Enter". Let me know if this helps. If it doesn't, check your anti-virus and turn it off before trying again.
https://linustechtips.com/topic/711971-forza-horizon-3-help/#findComment-9086139
