There are multiple kinds of wall switches. Some of them have more than 2 wires at the back. Could you give us a drawing of the electrical circuit?
CPU: Intel Core i5 4690K @ 4.6Ghz CPU Cooler: Noctua NH-D15 GPU: GTX 1070 TI RAM: Crucial Ballistix Tactical 16GB (4x4) Mobo: ASUS Z97-PRO(Wi-Fi ac) PSU: Corsair RM Series RM750 Case: Fractal Design Define R4 no window
7 minutes ago, CatFish9900 said:
snip
Its just electricity. Electricity does not know or care what its hooked up to. If you had sufficient knowledge, you could hook up literally any electrical device to a switch like that. It could be a phone, a toaster, a battery charger, a tv, anything.
Are you talking for a power switch? The way that works is the momentary button shorts the two pins for just a little bit and that tells the motherboard to get the party started. That's why you can start a computer with a flat head screw driver. You'll want a spring loaded momentary switch of you can, otherwise the motherboard will get confused and start force shutting down if those pins stay shorted.
ASU
yea for a power switch
so if i flick the switch quickly it will work but if i keep the switch on it wont work.
Or you could simply get a momentary switch as he rec'd and not have to flip on then off the switch to get the computer started lol.
But yes, that would work.
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
You could do it with a spring loaded switch. that its like starting your car and when you started it you let go and it goes in its original position.
I really like the idea please make pictures when it's finished and how you've done it I would really like this for my own pc!
  • 2 weeks later...
i was reading through this and yea a spring loaded switch is a good idea.
and ill send you a like to the build log if i do one
