corsair 200r fan placement
Patsy
What are people currently running when it comes to air in these cases?
Currently running stock cpu fan on an fx 8320, and the stock case fans (i think just the one at the front?)
What kind of setup should i run for minimal dust,
also i believe my psu is faced down,
PSU face down, as many intake fans as possible. Exhaust fans are what make dust accumulate.
|PSU Tier List /80 Plus Efficiency| PSU stuff if you need it.
My system: PCPartPicker || For Corsair support tag @Corsair Josephor @Corsair Nick || My 5MT Legacy GT Wagon ||
alrighty, so no exhaust fans at all? i still want decent cooling performance.
I have mesh side panel and i only have stock front and back fans on it. My PSU is facing down so it doesnt release wearm air into the case. I plan on putting 2 fans on top at some point in my life :D
Connection200mbps / 12mbps 5Ghz wifi
My baby: CPU - i7-4790, MB - Z97-A, RAM - Corsair Veng. LP 16gb, GPU - MSI GTX 1060, PSU - CXM 600, Storage - Evo 840 120gb, MX100 256gb, WD Blue 1TB, Cooler - Hyper Evo 212, Case - Corsair Carbide 200R, Monitor - Benq  XL2430T 144Hz, Mouse - FinalMouse, Keyboard -K70 RGB, OS - Win 10, Audio - DT990 Pro, Phone - iPhone SE
I'm just to lazy with this rig, i just want to build another one. something a little bit overkill
Well ideally you'll have one at the back of the case
As long as you have more fans for intake than exhaust, you are good. You need one exhaust to keep hot air going somewhere.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
