Hyper 212, does it still hold up?
Patsy
Hey guys, really need to overclock my cpu for a couple weeks, to meet a deadline on a 3d animation project. The software uses solely the cpu for rendering, so thought it might quicken up if i do some overclocking goodness.
Question, their isn't much cooling options when it comes to air where I live, but i do know my local stocks the hyper 212x, are these good enough to overclock an fx8350?
can someone also tell if this is a stable board to overclock on,
Gigabyte GA-970A-D3P
Not really, I would look for alternatives if possible. Deepcool Gammaxx 400, Cryorig H7, Raijintek Themis / Ereboss, Thermalright Macho (any version). Scythe Kotetsu
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
we aint got none of those brands around here lol.
What brands?
Computer Specs:
Mobo looks fine to overclock on.
Computer Specs:
It is good if you plan on running stock speeds, but for overclocking you are out of luck. Try water cooling if you can, i recommend cosair.
CPU: i7-6700K | Motherboard: MSI Z170A Krait Gaming 3X | RAM: Corsair Vengeance LPX 8GB DDR4-2666 Memory
Solid State Drives: Two PNY 120GB 2.5" Solid State Drives | GPU: EVGA GeForce GTX 1070 SC GAMING ACX 3.0 Black Edition
PSU: Thermaltake Smart 650W 80+ Bronze Certified ATX Power Supply | Case: Thermaltake Core V71 ATX Full Tower Case.
PCPartPicker
Just now, Energycore said:
What brands?
we've got,
a limited range of coolermaster,
deepcool (not the one you mentioned though)
corsair aio watercoolers
phanteks
cryorgis
zalman
couple of silverstone
and only the cheaper scythes
hopefully the h100i goes on sale, they very expensive out these ways.
Just now, Patsy said:
we've got,
phanteks
cryorgis
zalman
Cryorig H7, H5, R1
Which Deepcool?
Some stuff from Phanteks is fine.
Computer Specs:
the stock fan does pretty good on stock speeds as well, just sounds like a damn vacuum
it is worth it trust me, i built my friends build and its been running good for him. He overclocked his i7 6700k to 4.6.
PCPartPicker
A 212X will allow you a small overclock honestly, as long as temps don't go super high
Computer Specs:
Cryorig H7, H5, R1
Which Deepcool?
looks like we got some aio deepcool, 240, 140,120, these any good?
also got the deepcool frost twin, blade pro v2, gammmaxx 300,
I have always hated stock fans, whenever i receive one i through it over my fence. xD
PCPartPicker
$240 doe, might have to wait till i get paid lol, but that'll be after the projects finished, so no point.
lol, my noise canceling earphones do the trick for me.
Well patience is key when doing stuff with pc's, specifically when you are on a budget. It is all worth it when it is finished and paid off.
PCPartPicker
The deepcool AIO is fine, see if you can get it for less than the Corsair (take the cheapest honestly). And preferably a 240mm since the 120mm AIOs aren't so good.
Ow, don't pay that much for cooling!
Which Cryorig?
Computer Specs:
jokess, i only have an 8320, no 8350 silicon lottery for me.
Which Cryorig?
the deepcool aio, is 100 cheaper then the h100i, think around $160 for the 240
That's not terrible, pick that up if you want a liquid cooler
Computer Specs:
but i feel if i'm going liquid, aio are a bit of a beat around the bush? like might as well go for the real deal, but then i don't have a fancy case that can display all of my sik piping skills.
Nah custom loops cost a lot of money
Computer Specs:
you know what, im just gonna say fuck it with this overclocking, and save up and build a new rig done properly.
If you wait a couple months, we'll have new CPUs from AMD that might be a good value proposition :)
Computer Specs:
