Low fps although not reaching 100 percent usage
Solved by WereCat,
What cooler are you using and what temperature you are getting?
Your motherboard is not really good for handling this CPU and it may be throttling a lot due to overloading the VRMs.
Edit:
Actually I am positive it is because of that motherboard as it is VERY bad. Your CPU is 220W TDP and you need at least 990FX board for it, yours its for the FX4000 series CPUs and even those will be pushing it.
Featured Topics
Dreamer ·
Posted in Storage Devices0 -
Tawatchai ·
Posted in Troubleshooting1 -
1
papa_lima_sierra ·
Posted in Windows0 -
3
HELLLLLLLLLLPPP ·
Posted in PC Gaming1 -
Vectraat ·
Posted in Peripherals2
play_circle_filled
Latest From ShortCircuit:
Feels like I'm wearing nothing at all... - Shokz OpenFit Air
