So my friend is planning on building that can run most games maxed out at 8-12k. He does not care about price. What would be a good parts list for my friend as I will be building his system.
System
  • CPU
    I7 6700K Overclocked to 4.6 GHz at 1.33v
  • Motherboard
    Asus Z270 PRIME - A
  • RAM
    GSKILL RIPJAWS V DDR4 16GB 3000MHZ
  • GPU
    MSI GTX 1070 GAMING X 8G overclocked to 2063 MHZ and 8900 MHZ memory clock
  • Case
    NZXT S340 RED
  • Storage
    WD 1TB BLUE AND SAMSUNG EVO 250GB SSD
  • PSU
    EVGA 650W GQ
  • Display(s)
    LG 25UM58-P ULTRAWIDE and LG 29UM58-P 29 ULTRAWIDE
  • Cooling
    CORSAIR H100I GTX
  • Keyboard
    CORSAIR K70
  • Mouse
    LOGITECH G502 PROTEUS SPECTRUM
  • Operating System
    Windows 10 PRO
https://linustechtips.com/topic/707863-insane-build-pls-help/
single gpu or sli
https://linustechtips.com/topic/707863-insane-build-pls-help/#findComment-9042069
Just now, masterkickass7 said:
single gpu or sli
Whatever gives the frames/eye candy
System
  • CPU
  • Motherboard
    Asus Z270 PRIME - A
  • RAM
  • GPU
  • Case
    NZXT S340 RED
  • Storage
  • PSU
    EVGA 650W GQ
  • Display(s)
  • Cooling
    CORSAIR H100I GTX
  • Keyboard
    CORSAIR K70
  • Mouse
  • Operating System
    Windows 10 PRO
https://linustechtips.com/topic/707863-insane-build-pls-help/#findComment-9042073
whats he playing at
https://linustechtips.com/topic/707863-insane-build-pls-help/#findComment-9042075
Just now, deXxterlab97 said:
8-12k he said that
think thats his budget
https://linustechtips.com/topic/707863-insane-build-pls-help/#findComment-9042080
So eventually something like this?
CPU: Intel Core i7-6950X 3.0GHz 10-Core OEM/Tray Processor  ($1809.00 @ Newegg Marketplace)
CPU Cooler: NZXT Kraken X62 Liquid CPU Cooler  ($159.99 @ Newegg)
Motherboard: Gigabyte GA-X99-Designare EX ATX LGA2011-3 Motherboard  ($418.95 @ B&H)
Memory: Avexir Raiden 16GB (2 x 8GB) DDR4-2800 Memory  ($156.99 @ Newegg)
Storage: Samsung 950 PRO 512GB M.2-2280 Solid State Drive  ($314.99 @ Jet)
Storage: Seagate Archive 8TB 3.5" 5900RPM Internal Hard Drive  ($233.98 @ SuperBiiz)
Case: NZXT Noctis 450 ATX Mid Tower Case  ($136.99 @ SuperBiiz)
Power Supply: EVGA SuperNOVA G2 1600W 80+ Gold Certified Fully-Modular ATX Power Supply  ($299.99 @ SuperBiiz)
Video card: NVIDIA Titan X (Pascal) 12GB Video Card (4 way SLI) ($4800.00 @ Nvidia )
Total: $8801.85
Generated by PCPartPicker 2016-12-16 22:40 EST-0500
https://linustechtips.com/topic/707863-insane-build-pls-help/#findComment-9042081
No that's the resolution my friend wants to play at... he has no budget.
System
  • CPU
  • Motherboard
    Asus Z270 PRIME - A
  • RAM
  • GPU
  • Case
    NZXT S340 RED
  • Storage
  • PSU
    EVGA 650W GQ
  • Display(s)
  • Cooling
    CORSAIR H100I GTX
  • Keyboard
    CORSAIR K70
  • Mouse
  • Operating System
    Windows 10 PRO
https://linustechtips.com/topic/707863-insane-build-pls-help/#findComment-9042082
we since he says he doesn't care how much it costs im thinking he wants to play games in 8k and 12k what is pretty much a dumb idea, even 8k downscaled to 4k will cause stuttering/frame drops in game just becase they are not made to run at the rez, even with dual 1080s
Everyone should own a vive.
https://linustechtips.com/topic/707863-insane-build-pls-help/#findComment-9042084
Why you assume someone must run 1080? Why not Titan X?
https://linustechtips.com/topic/707863-insane-build-pls-help/#findComment-9042090
Other: NVIDIA Titan X (Pascal) 12GB Video Card (4 way SLI) ($4800.00)
Total: $8801.85
Would these parts be able to run all games maxed at 8-12k? Those are some beefy specs but can it handle that resolution?
System
  • CPU
  • Motherboard
    Asus Z270 PRIME - A
  • RAM
  • GPU
  • Case
    NZXT S340 RED
  • Storage
  • PSU
    EVGA 650W GQ
  • Display(s)
  • Cooling
    CORSAIR H100I GTX
  • Keyboard
    CORSAIR K70
  • Mouse
  • Operating System
    Windows 10 PRO
https://linustechtips.com/topic/707863-insane-build-pls-help/#findComment-9042092
well there was a post on here a few days ago about a guy running a game at 8k and with dual 1080s and i7 6600k i think and he had issues, I personally wouldn't use a titan x to game id pick a 1080 over that
https://linustechtips.com/topic/707863-insane-build-pls-help/#findComment-9042096
Linus got 25fps max (I believe) on 8K with Crysis 3. I assume you can scale these cards right and do some overclock then maybe yes
https://linustechtips.com/topic/707863-insane-build-pls-help/#findComment-9042099
https://pcpartpicker.com/user/masterkickass7/saved/#view=nMvjXL
https://linustechtips.com/topic/707863-insane-build-pls-help/#findComment-9042101
You haven't watch this I assume lol
https://linustechtips.com/topic/707863-insane-build-pls-help/#findComment-9042102
consider games are not made to be played at the rez there might be frame drops in some parts for some games,
but i knida highly doubt this rig or any rig capable of that will be made unless your friend is a millionair
https://linustechtips.com/topic/707863-insane-build-pls-help/#findComment-9042103
well he is asking to run it, not to have an orgasm with the fps
well id think he wants a framerate that doesn't look like ass, especially when he has infinite amount of money to spend
https://linustechtips.com/topic/707863-insane-build-pls-help/#findComment-9042113
12 minutes ago, deXxterlab97 said:
8-12k he said that
You mean, he wants to run games in 8-12k?:o That's new.:D
CPU: Intel Core i5-6600K, Motherboard: MSI Z170A GAMING M5, RAM: G.Skill DDR4 2 x 8GB GPU: MSI GTX 1070 Gaming X, Case: Cooler Master MasterCase 5
Storage: WD Blue 1TB, Samsund 850 EVO 250 GB, PSU: Corsair RM 750X, Display(s): BenQ BL2710PT: Cooling: Thermalright True Spirit 140 Power
Mouse: Gamdias DEMETER II- 3200DPI Gaming Mouse, Operating System: Windows 8.1
https://linustechtips.com/topic/707863-insane-build-pls-help/#findComment-9042120
Pile on the titan Xs then.
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
https://linustechtips.com/topic/707863-insane-build-pls-help/#findComment-9042121
your monster is done
https://linustechtips.com/topic/707863-insane-build-pls-help/#findComment-9042138
CPU: Intel Core i7-6950X 3.0GHz 10-Core Processor  ($1599.79 @ SuperBiiz)
CPU Cooler: Corsair H110i GTX 104.7 CFM Liquid CPU Cooler  ($149.99 @ Corsair)
Motherboard: MSI X99A GAMING 9 ACK EATX LGA2011-3 Motherboard  ($384.77 @ Amazon)
Memory: G.Skill TridentZ Series 64GB (4 x 16GB) DDR4-3466 Memory  ($544.99 @ Newegg)
Storage: Samsung 960 Pro 1.0TB M.2-2280 Solid State Drive  ($605.99 @ SuperBiiz)
Case: Phanteks Enthoo Luxe ATX Full Tower Case  ($148.70 @ Jet)
Power Supply: EVGA SuperNOVA T2 1600W 80+ Titanium Certified Fully-Modular ATX Power Supply  ($382.99 @ SuperBiiz)
Other: 4 Titan X Pascal+SLI bridge ($4880.00)
Total: $8931.20
Generated by PCPartPicker 2016-12-16 23:00 EST-0500
https://linustechtips.com/topic/707863-insane-build-pls-help/#findComment-9042145
Dont listen to the people saying to buy a 6950x. Its a waste of money, not even from a price standpoint, it will perform worse than a 6700k or 6800k with a good OC
CPU: I5 4590 Motherboard: ASROCK H97 Pro4 Ram: XPG 16gb v2.0 4x4 kit  GPU: Gigabyte GTX 970 PSU: EVGA 550w Supernova G2 Storage: 128 gb Sandisk SSD + 525gb Mx300 SSD Cooling: Be Quiet! Shadow Rock LP Case: Zalman T2 Sound: Logitech Z506 5.1 Mouse: Razer Deathadder Chroma Keyboard: DBPower LED
https://linustechtips.com/topic/707863-insane-build-pls-help/#findComment-9042149
