EVGA 600b is enough for gtx 970 sli?
Noxzt
Hello people, i have the evga 600b 80 plus bronze, is enough for gtx 970 sli?
i5 6500
gigabyte b150m-d3h-gsm
16gb ddr4
Sorry for my bad english
Does the PSU supply 4 x 6-pin PCIE connectors or at least 3 without using an adapter?
idk
2 minutes ago, 3DGamerOnSteam said:
I don't think that board will even support sli.
yep, only supports 2way cf. SLI and CF are a waste of time anyway, buy 1070 instead of 2x970
idk
Ya only Z boards support SLI.
600 would be just enough, but that board won't support SLI, so you would need a new motherboard. You need at least 8x pcie lanes to run SLI, you only have a 16x and a 4x.
No, it's up to how many pcie lanes you have. you have to run 8x 8x or higher, he can only run 8x 4x. As long as your board has 2 8x plus lanes, sli will work.
1 minute ago, 3DGamerOnSteam said:
No, it's up to how many pcie lanes you have. you have to have run 8x 8x, he can only run 8x 4x. As long as your board has 2 8x plus lanes, sli will work.
True, but I think on the non-Z boards you have the high potential to bottleneck your video cards with the CPU not being all that great (depending on the specific CPU anyways), so doing SLI on mid-range cards would be a no-go, least in my opinion.
i5 6500
16gb ddr4
Let's start off by saying I doubt your board supports SLI.
Second, don't SLI 970s. Get one single better GPU.
Third, do not attempt to power two cards on a 600B. It's not that great quality or performing and should not be powering two GPUs.
|PSU Tier List /80 Plus Efficiency| PSU stuff if you need it.
My system: PCPartPicker || For Corsair support tag @Corsair Josephor @Corsair Nick || My 5MT Legacy GT Wagon ||
