Liquid Cooling or Air Cooling
This is my build
MSI Z170 M5 MOBO
I5 6600K CPU
Cooler Master MasterCase 5 Windowed Mid Tower Case
And the rest of the normal stuff, I'm stuck at what cooling method to choose. I'm not gonna go Overclocking right out of the box, so what should I choose?
Note: This is my first build, and my first time doing anything remotely related to PC build. So, a non technical answer is appreciated.
CPU: Intel Core i5-6600K, Motherboard: MSI Z170A GAMING M5, RAM: G.Skill DDR4 2 x 8GB GPU: MSI GTX 1070 Gaming X, Case: Cooler Master MasterCase 5
Storage: WD Blue 1TB, Samsund 850 EVO 250 GB, PSU: Corsair RM 750X, Display(s): BenQ BL2710PT: Cooling: Thermalright True Spirit 140 Power
Mouse: Gamdias DEMETER II- 3200DPI Gaming Mouse, Operating System: Windows 8.1
https://linustechtips.com/topic/706166-liquid-cooling-or-air-cooling/
if your not going to overclock it i wouldn't bother with a water cooler if you are planning to do so in the future than think about it otherwise its not really worth it.
Edited by Kantor
unnesisary space in the word cooler
build: Frankenstein http://au.pcpartpicker.com/list/QLBRVY
i know it's nuts but the drives i bought over time as i need more storage.
6 minutes ago, steve-kon said:
This is my build
MSI Z170 M5 MOBO
I5 6600K CPU
Water cooling is more expensive, but cools more than air cooling. Not really needed when not overclocking, but good when you plan on overclocking.
Even when overclocking, I would choose air cooling unless you're doing a full custom loop including your graphics cards in it. (If you have room for this): The Noctua ND-H15 actually performs BETTER than plenty of great AIO coolers, and comes in at around $85, compared to the $100-$150 that I normally see on the water loops. On top of that, it comes with 2 of the best fans on the market, which never goes out of style. Last major point is that air coolers are quieter and have less moving parts, so there's less to make noise and less to go wrong. I use this cooler and have my 4790K running at a 0.8 GHz overclock full time, and it never gets warmer than I eat my pizza. Here's Linus' original video with AIO comparison to the one I recommend.
Air. Water has way too many possible flaws and Air can look awesome too. Temp wise there no serious difference compared to a nice Air Setup.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
12 minutes ago, Kantor said:
if your not going to overclock it i wouldn't bother with a water cool er if you are planning to do so in the future than think about it otherwise its not really worth it.
6 minutes ago, Praesi said:
Air. Water has way too many possible flaws and Air can look awesome too. Temp wise there no serious difference compared to a nice Sir Setup.
I think I'll go with air cooling for now. Thanks for the replies.
14 minutes ago, ragepoweredgamer said:
Even when watercooling, I would choose air cooling unless you're doing a full custom loop including your graphics cards in it. (If you have room for this): The Noctua ND-H15 actually performs BETTER than plenty of great AIO coolers, and comes in at around $85, compared to the $100-$150 that I normally see on the water loops. On top of that, it comes with 2 of the best fans on the market, which never goes out of style. Last major point is that air coolers are quieter and have less moving parts, so there's less to make noise and less to go wrong. I use this cooler and have my 4790K running at a 0.8 GHz overclock full time, and it never gets warmer than I eat my pizza. Here's Linus' original video with AIO comparison to the one I recommend.
I must be living on a different planet, that model costs me $200.
is it just me or are you a marketing guy working at noctua? :P
ps: theyre good but god dang ugly
Air coolers can perform very well but are limited in size due to the area around the motherboard. Liquid cooling can achieve higher performance with more surface area by placing radiators away from the motherboard.
If you don't need as high of an oc as possible, air cooling will almost always be plenty and usually be the quieter choice due to the lack of pump noise.
OK, that's that then. It all depends on my preference, that's not very encouraging(just kidding). As I have said before i'm new to this PC build thing so I have not a slightest idea about the cpu cooler installing. But I have a small doubt regarding installing the CPU cooler. I have this case(not yet, it still didn't reach me) it comes with a 140mm rear fan preinstalled, so the cooler I should look for is a 140mm sized one right? Or can I get a 120mm Cooler and replace the preinstalled 140mm fan with a 120mm fan?
Cooler Master MasterCase 5 Windowed Mid Tower Case (MCX-0005-KWN00)
As I said I know nothing about these, so forgive me if I sound dumb.
The rear fan size has nothing to do with the size of the cooler you should get for your cpu.
If you want a specific recommendation, tell us what you're looking for in a cooler, where you're shopping/located, and your budget.
I ordered this and cancelled it seeing it is a 120mm variant. Is it good though?
DeepCool CPU Liquid Cooler CAPTAIN 120 EX WHITE , any cooler from 100-150 dollars would be great as i have to pay 50 dollars or more in my country.
120mm AIO's usually aren't worth getting in the first place since air coolers in the same price range will usually perform as well or better while being quieter.
What kind of dollars are you using and why do you have to pay more than $80?
Suppose a Noctua NH-D15 CPU Cooler costs $87.75 in newegg.com, I get it for $198.45 in my country.
I live in India fyi.
Is that USD in both cases?
Can you link us to where you're shopping? What's your budget?
You need to quote a post or tag a member or else they won't get a notification you replied to them.
That is USD on both the cases..
amazon.in is where i shop for products..
100 - 150 dollars for CPU Coolers..
The site doesn't use USD. What your budget in INR?
10,000 INR
11 minutes ago, WoodenMarker said:
Thanks, the Phanteks cooler looks good, but in the comment section it says something like this "As with any cooler this large, you have to be aware of potential RAM clearance issues. If your RAM is too tall, that could be a problem. " I will be using a G-Skill Ripjaws V model ram, would it be a problem?
The cooler has 40mm of clearance for ram. Ripjaws V is 42mm tall. If you're planning a new system, just get ram that isn't unnecessarily tall.
check newegg india noctua coolers doesn't cost lot in shipping as they ship from Austria i belive so do check newegg india.
I already have a got the RAM, can't change that. Can you please suggest an alternative. Thanks.
I know it costs less even if I ship it from newegg but newegg allows only credit card payments and my credit card is inactive right now so I don't think i'll be able to do that.
True Spirit 140 Power: http://www.amazon.in/Thermalright-True-Spirit-140-Power/dp/B00IYEEOMO/ref=sr_1_51?ie=UTF8&qid=1481750495&sr=8-51&keywords=thermalright
If it overhangs the first ram slot with the fan in front, you can mount in on the other end of the heatsink for pull instead.
