In-Car Bluetooth (Audio)
Go to solution Solved by treeroy,
What about something like this? Just a Bluetooth receiver that plugs straight into the aux port. By the looks of it, it only needs to be charged, doesn't need to be always plugged in, so you could charge it overnight.
https://www.amazon.co.uk/Bluetooth-Receiver-Portable-Microphone-Streaming/dp/B00Y29NXEA/ref=sr_1_3?ie=UTF8&qid=1481619804&sr=8-3&keywords=bluetooth+aux
Also, you CAN use a USB power source, just buy a USB cigarette lighter plug, they only cost a fiver.
So, I have a 2010 Mini Cooper R56 which didn't come with Bluetooth or any USB ports. It does however have an AUX port and a 12V.
Basically, I just want to connect my phone to my car for playing music wireless. I'd prefer to be able to make phone calls and use voice recognition as well, but that's not necessary.
So far I've looked into using a Google Chromecast Audio, and the Belkin Caraudio Connect AUX.
The Google Chromecast Audio needs power from a USB which I don't have, and a WiFi network to connect to.
The Belkin Caraudio Connect AUX is exactly what I need, except it isn't any good judging from reviews (TechMoan) and is outdated.
Any ideas?
"Those who are last are sideways and smiling". - Jeremy Clarkson
https://linustechtips.com/topic/706066-in-car-bluetooth-audio/
Any ideas?
Is upgrading to a stereo that has bluetooth built in out of the question?
Case - NZXT H6 Flow : Mobo - ASRock X670E PG Lightning : PSU - Deepcool PX1000G : CPU - AMD Ryzen 9 7900X3D w/Arctic Freezer III 360  : Memory - G.Skill Ripjaws S5 32gb 6000mhz CL30 : GPU - MSI Expert 4080 Super : Storage - Verbatim Vi7000G 4tb NVME SSD  : Displays - Gigabyte 32" M32QC Curved 165hz & 27" M27Q Pro 165hz 1440p
https://linustechtips.com/topic/706066-in-car-bluetooth-audio/#findComment-9020815
2 minutes ago, NPSTR107 said:
Yep. :)
Then Belkin Caraudio Connect Aux there isn't really anything else, there other brands that do the same thing so maybe google around a little bit.
https://linustechtips.com/topic/706066-in-car-bluetooth-audio/#findComment-9020835
Any ideas?
can you splice 12 v from your car into the chromecast? can you use your phone hotspot for wifi?
https://linustechtips.com/topic/706066-in-car-bluetooth-audio/#findComment-9020846
GTX 3080 Ti ROG | Ryzen 5600X | MSI Tomahawk B550 | 32GB 3600MHz | Corsair 850e | HAF X | WD SN850X | Asus MG287Q 1440p 144Hz
https://linustechtips.com/topic/706066-in-car-bluetooth-audio/#findComment-9021208
4 hours ago, treeroy said:
That's a great find! I'm going to do more research into that. Seems small and unobtrusive, i'll just have to find a nice flush 12V USB Adapter.
Cheers
https://linustechtips.com/topic/706066-in-car-bluetooth-audio/#findComment-9021806
I don't really want to fiddle with the car that much, just looking for a quick solution.
https://linustechtips.com/topic/706066-in-car-bluetooth-audio/#findComment-9021811
Cheers
I personally use this, it's such a handy little thing to have in your car:
https://www.amazon.co.uk/Lifetime-Warranty-RAVPower-Charging-Protection/dp/B00Q2GFP4M/ref=sr_1_4?s=electronics&ie=UTF8&qid=1481635693&sr=1-4&keywords=usb+car+charger
My car is from 2002 so has no modern tech in it at all, but there are plenty of ways to make do. Just have to look around - or ask on internet forums like this haha. :)
https://linustechtips.com/topic/706066-in-car-bluetooth-audio/#findComment-9021817
Any ideas?
I had this issue with by 2006 Renault Clio. The cheapest alternative is to get a mic and a 2 mic and headset adapter. It requires a lot of cable tidying but works
Main Rig - Case: Fractal Design Pop Air XL Motherboard: Asus TUF B650 Plus WIFI CPU: AMD Ryzen 5 7600 RAM: Corsair Nautilus 240 RAM: Corsair Vengeance 16GB 3000MHz32GB Corsair Vengeance DDR5 6000MHz  SSD: 1 TB 1TB Samsung 990 Pro NVMe
HDD: 2TB WD Blue  GPU: Asus RTX4070 Dual Evo PSU: Corsair RM850X
Corsair 200R Front Bezel Mod
https://linustechtips.com/topic/706066-in-car-bluetooth-audio/#findComment-9021850
I'm in Australia so i'll just have to find something similar that's cheaper. Shipping is expensive on Amazon.com if you buy from Australia.
https://linustechtips.com/topic/706066-in-car-bluetooth-audio/#findComment-9021855
Holy shit, Amazon isn't in Australia? Wow. Didn't know that.
Well good luck anyways - I'm sure there are loads of USB car chargers in Australia too. Dunno where you guys get your shopping.
https://linustechtips.com/topic/706066-in-car-bluetooth-audio/#findComment-9021891
Well, there is Amazon in Australia but they only sell books and stuff.
I'm going to buy two of those MPOW Bluetooth Recievers (AUD$19each) wish me luck.
https://linustechtips.com/topic/706066-in-car-bluetooth-audio/#findComment-9047880
