Help - Explorer.exe crash win 10
Hi guys.
I'm using win 10 and my explorer.exe is crasching and it's freeze my all my pc. Only my mouse are able to use. Anyone knows how can I fix it?
Sorry about my poor english.
Ryzen 5 5600x -- 2x8 Kingston Hyperx fury 8gb 2133mhz/2400Mhz -- Sandisk SSD Ultra II 120gb/240gb -- PSU EVGA 600b B1 -- Case Cougar Gemini S -- Mobo ASROCK B450M Steel Legend -- GTX 1060 6GB Galaxy
https://linustechtips.com/topic/705950-help-explorerexe-crash-win-10/
How did you install windows 10?
How long has this been happening? Did something major happen prior to this? Can you access file ok? Is this the specs in your sig? And if so, do you have HDD installed?
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
@LoGiCalDrmIt's happening about 2 weeks and it's the only thing happen with my PC. I'm using ssd.
Did you do something or did windows update something before this started? Have you tried to repair installation? It sounds like corrupted OS. Or RAM acting up. Hard to say which. I'd also change both cable and port for SSD to rule those out.
I think that happen because I used drive booster to update all my drivers... I will uninstall everything and reinstall with the brand.
