As others have said, simply touch the case every once in awhile, handle components at their edges, away from connectors and such.
Frying your equipment has come to be more of a myth than anything. Unless you're wearing wool and walking on the carpet shuffling your feet, and then actually touching non-PCB areas of the components, you're not going to fry anything.
https://linustechtips.com/topic/705933-building-on-carpet/#findComment-9019217
I built my first custom rig while on sitting on a carpet floor. Nothing has gone wrong with that  system, despite me accidentally bending the motherboard (but it still works).
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
https://linustechtips.com/topic/705933-building-on-carpet/#findComment-9021632
I used to think all of the static talk was just to scare people, because I built several PCs before I knew you could kill electronics with static electricity.  Or that carpet can build up a massive static charge.
From what I have learned since then, it is the case that originally, at some not so distant point in our past, motherboards were not as robust as they are today.  Those motherboards could easily be damaged by static discharge.  The modern motherboards are built intentionally so that static is not nearly as dangerous to them, and so it's more of a myth to hear about static discharge actually damaging a component than it is a real danger.
That being said, there's no reason not to err on the side of caution (myth perpetuated :) )
https://linustechtips.com/topic/705933-building-on-carpet/#findComment-9021639
