4 minutes ago, Over9000Dude said:
Hello, its me, i was wondering if you guys know any good custom liquidcooling cases under $120 (other than Define S)
Sure, there's the Phanteks (literally all of them work well), Corsair 400 series, Thermaltake Core V21 was fun for me, H440, so on and so forth.
Perhaps give us some details of the parts you plan on using to narrow the options down.
Main Rig: R9 5950X @ PBO, RTX 3090, 64 GB DDR4 3666, InWin 101, Full Hardline Watercooling
Server: R7 1700X @ 4.0 GHz, GTX 1080 Ti, 32GB DDR4 3000, Cooler Master NR200P, Full Soft Watercooling
LAN Rig: R5 3600X @ PBO, RTX 2070, 32 GB DDR4 3200, Dan Case A4-SFV V4, 120mm AIO for the CPU
HTPC: i7-7700K @ 4.6 GHz, GTX 1050 Ti, 16 GB DDR4 3200, AliExpress K39, IS-47K Cooler
Router: R3 2200G @ stock, 4GB DDR4 2400, what are cases, stock cooler
I don't have a problem...
https://linustechtips.com/topic/705824-liquid-cooling-case/#findComment-9017614
H440
- ASUS X99 Deluxe - i7 5820k - Nvidia GTX 1080ti SLi - 4x4GB EVGA SSC 2800mhz DDR4 - Samsung SM951 500 - 2x Samsung 850 EVO 512 -
- EK Supremacy EVO CPU Block - EK FC 1080 GPU Blocks - EK XRES 100 DDC - EK Coolstream XE 360 - EK Coolstream XE 240 -
https://linustechtips.com/topic/705824-liquid-cooling-case/#findComment-9017617
H440 is alright, worse airflow though
Most of the Thermaltake cases, though I'm not a fan of how they run their business
Phanteks and Corsair have a lot of good ones in your budget. (P400, for example)
BOINC Setup:
i5 7200U @ Stock
Core2Duo T6600 @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/705824-liquid-cooling-case/#findComment-9017622
