6 minutes ago, chowderblue said:
Think that's just an oversight on their webpage, that's an adapter. Meaning you attach that to something, and ANOTHER fitting to it. So, it should be compatible with that tubing, since all it is does is essentially relocate the hole your fitting screws into.
Main Rig: R9 5950X @ PBO, RTX 3090, 64 GB DDR4 3666, InWin 101, Full Hardline Watercooling
Server: R7 1700X @ 4.0 GHz, GTX 1080 Ti, 32GB DDR4 3000, Cooler Master NR200P, Full Soft Watercooling
LAN Rig: R5 3600X @ PBO, RTX 2070, 32 GB DDR4 3200, Dan Case A4-SFV V4, 120mm AIO for the CPU
HTPC: i7-7700K @ 4.6 GHz, GTX 1050 Ti, 16 GB DDR4 3200, AliExpress K39, IS-47K Cooler
Router: R3 2200G @ stock, 4GB DDR4 2400, what are cases, stock cooler
I don't have a problem...
Here is an example of a similar product, so you can more easily see how it would be used: https://www.dazmode.com/store/product/90_degree_rotary_adapter_m_f_g1_4_black_bp-mb90r/
So Tubing goes to Barb fitting (or compression) then have a "washer" to clamp it onto the barb fitting, then have the adapter onto that to make a turn?
So let's say you want to connect a tube to a GPU water block; you would have a chain like this:
GPU block
90 degree adapter
compression/barb fitting
clamp/compression ring
tube
GPU block
90 degree adapter
tube
ok so what if i need to make a turn into the tube, however i do not want to bend the tube and i just want to use an adapter, i would then have tube - compression/barb fitting - clamp/compression ring - adapter - compression/barb fitting - clamp/compression ring - tube
No, this (and most) adapter(s) has a male thread on one end, meaning it goes into the component directly, so it'd be exactly like I outlined earlier:
Component
Adapter
Fitting
tube
more tube (same piece, technically you put the ring on the tube, slide the tube into the fitting, then clamp it down, so visually it looks like this)
Component
Adapter
Fitting
tube
ah, so only one end can connect to a tube, the other connects to a component. Meaning i got it wrong with the number i bought lol, i only need however many screws are in my radiator and water block. so like 4-5?
Well this is generally what you need:
2 for the CPU block (in and out)
2 for each GPU block
2 for each radiator
2 for the reservoir
2 for the pump UNLESS you have a pump/res combo unit
1 more for the adapter you will use to split the flow somewhere and create a drain valve (yes, do this)
2 more because you always forget something or one could be faulty, plus they are handy
and all the adapters you may need (angled adapters, flow splitters like I mentioned for the drain valve, etc.)
