The pre applied stuff on corsairs AIO's is decent, changing it to something else would probably only help for a degree or two.
https://linustechtips.com/topic/703692-thermal-paste-question/#findComment-8994643
just you whats already on it, there'll be little temp difference applying your on, and corsair is usually pretty dam good for the quality of their products all around.
Silent build - You know your pc is too loud when the deaf complain. Windows 98 gaming build, smells like beige
https://linustechtips.com/topic/703692-thermal-paste-question/#findComment-8994646
