Hey Everyone, I am building a PC for my uncle who is 65 years old. He liked the Fractal Design Core 500 case so I have chosen that for him. He will not be doing any video editing or gaming at all and will be only browsing, however he wants it to last a while. I don't want to put two drives otherwise that will likely confuse him and that is why I opted for a single 850 evo 500gb SSD. Can you tell me if you think I should put less ram or if I could improve anything. Thanks
https://au.pcpartpicker.com/list/7Vzdd6
https://linustechtips.com/topic/702277-building-a-pc-for-uncle/
Power supply is way overpriced for 450W
Other than that. it's good.
keep in mind that no matter how fast the hardware, a clean install of windows every few years does wonders to a PC.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/702277-building-a-pc-for-uncle/#findComment-8976897
I think the power supply's overpriced as well but at the place we are buying it from at Mwave Australia, anything cheaper looked super dodgy. Hes coming from an ancient core 2 duo
https://linustechtips.com/topic/702277-building-a-pc-for-uncle/#findComment-8976906
Like the others already mentioned, the PSU is sort of expensive. Other than that it looks good to me.
ProTip: Don't give him the admin password / Install Teamviewer / install adblocker / replace the chrome icon with that blue E thing / set youporn as standard homepage so he doesn't need to browse the web for even fishier sides... :-)
https://linustechtips.com/topic/702277-building-a-pc-for-uncle/#findComment-8976930
I get that you want it to be a decent system, but honestly he probably won't notice the difference between an i5 and a G4400.
Also, there's no real need for more than 4GB of RAM.
I'd also get a cheaper SSD. No need for the 850 EVO.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/702277-building-a-pc-for-uncle/#findComment-8976937
Like the 750 EVO, will that be as fast as the 850 even with that being his main and only drive.
https://linustechtips.com/topic/702277-building-a-pc-for-uncle/#findComment-8977005
Is their a way to put no admin password on windows 10
https://linustechtips.com/topic/702277-building-a-pc-for-uncle/#findComment-8977010
20 minutes ago, mok said:
honestly an i3+8gb ram+SSD will be flying for a long time.
Do you also think I could get away with an i5 6400
https://linustechtips.com/topic/702277-building-a-pc-for-uncle/#findComment-8977015
by a default install you can leave the admin pw blank and the first user registered to the system will be admin without password protection.
which is a great idea, if your uncle got a nice aunt who makes fantastic cake that you like, because you will be there every other day to eat said cake while fixing the pc :-)
yep, totally, sounds like a browser only machine anyway, so that one will do, actually it will be overkill, but will be able to run chrome in 5 years from now (most likely :-))
https://linustechtips.com/topic/702277-building-a-pc-for-uncle/#findComment-8977026
Ok Cool, will it be able to handle microsoft applications with only 8 gb ram
https://linustechtips.com/topic/702277-building-a-pc-for-uncle/#findComment-8977033
yep it will run word / excel and other office programs without issues. 8GB Ram will only be needed for browsing when using chrome :-)
8GB RAM is more than enough these days for the normal office / browser machine.
https://linustechtips.com/topic/702277-building-a-pc-for-uncle/#findComment-8977046
Thanks for your help!
https://linustechtips.com/topic/702277-building-a-pc-for-uncle/#findComment-8977050
CPU: Intel Pentium G4400 3.3GHz Dual-Core Processor  ($78.00 @ Shopping Express)
Motherboard: ASRock H170M-ITX/ac Mini ITX LGA1151 Motherboard  ($154.00 @ Skycomp Technology)
Memory: G.Skill Ripjaws 4 series 8GB (2 x 4GB) DDR4-2133 Memory  ($56.00 @ Umart)
Storage: Crucial MX300 525GB 2.5" Solid State Drive  ($169.00 @ Shopping Express)
Case: Fractal Design Core 500 Mini ITX Desktop Case  ($89.00 @ PCCaseGear)
Power Supply: Corsair 430W 80+ Bronze Certified ATX Power Supply  ($65.00 @ IJK)
Total: $611.00
Generated by PCPartPicker 2016-12-05 18:05 AEDT+1100
https://linustechtips.com/topic/702277-building-a-pc-for-uncle/#findComment-8977054
16 hours ago, chris76816 said:
Do you think Intel Graphics 530 will be fine for him
Way more than enough. To put it into context, I have a much, much weaker iGPU and I easily run Diablo 3 and other games.
You can get away with something like a PS1211, or SP550 from Adata. You don't need a Samsung. The difference will not be noticed.
I have 4GB of RAM and I always have around 50 tabs open.
So no, you don't need 8GB of RAM. This isn't likely to change any time soon.
Total: $611.00
That is drastically overkill.
You don't need a motherboard anywhere near that expensive, and that SSD has way, way more space than needed.
https://linustechtips.com/topic/702277-building-a-pc-for-uncle/#findComment-8980695
He's a lawyer though and price isn't really an issue. He just wants it to be really fast.
https://linustechtips.com/topic/702277-building-a-pc-for-uncle/#findComment-8981333
Spending more won't make it faster. The tasks you've listed don't require anything more than a basic processor.
It's like living in a dense city and driving a car with a 500hp engine. Sure, you could go fast, but you'll never use it.
https://linustechtips.com/topic/702277-building-a-pc-for-uncle/#findComment-8981889
