I'm trying to remotely connect to my laptop from my main rig. My main rig is running Win10 home and my laptop is running Win10 Pro. I've made sure all the settings are correct. When I try to connect to the laptop, I type in my credentials correctly. but it says "The logon attempt failed". I don't know why it is saying this when I'm sure everything is correct. Can i have some help pls? Thx.
AMD FX 6300 @ 4.6 Ghz CRYORIG H7 Asus M5A97 PLUS | HyperX Fury 8 GB DDR3 | PNY CS1311 120gb SSD WD Blue 1TB 7200 RPM EVGA GeForce GTX 950 Superclocked NZXT Source 210 Black EVGA 500B Logitech G Pro HP K3500 Wireless Keyboard |
https://linustechtips.com/topic/701538-rdc-being-stubborn/
Just now, Electronics Wizardy said:
Are you using a domain? Im guessing your typing it in wrong though.
I'm just typing in the computer name. Then it asks me for username/password and such. The thing is though I'm typing in everything correctly
https://linustechtips.com/topic/701538-rdc-being-stubborn/#findComment-8968425
If you're not using a domain try putting a \ in front of the username so it doesn't try to use a domain name, sometimes it helps.
Also, see what happens if you completely disable the firewall.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/701538-rdc-being-stubborn/#findComment-8968426
Did both and still didnt work
https://linustechtips.com/topic/701538-rdc-being-stubborn/#findComment-8968443
Try inputting the username with the hostname of the laptop before. So if the computer is called "Tom-Laptop" and the username is "Tom" you would type "Tom-Laptop\Tom" - this makes sure the computer knows it's a local account. Also, if you have the same username on both computers, they should have the same password. Windows gets weird if you have the same username with different passwords.
Edit: Also, on the laptop, make sure that remote logins are enabled, and that the user is either an administrator, or explicitly added to the list of remote desktop users.
Looking to buy GTX690, other multi-GPU cards, or single-slot graphics cards:
https://linustechtips.com/topic/701538-rdc-being-stubborn/#findComment-8970561
