New TV need help calibrating
Go to solution Solved by BrinkGG,
4 minutes ago, kol said:
Got a new TV yesterday and need some help calibrating it. What is the best way to do this? Any tips?
Samsung UE32K1500
Use a site like tweaktv to find the best picture settings for it.
This is the closest I could find. http://www.tweaktv.com/tweak-my-tv/calibration-guide/samsung-ue32c6600.html
To be honest I think you're over thinking it.  You certainly can use something like a Spyder from Datacolor to 'professionally calibrate' your TV and even BestBuy tried to upsell me on calibration services.  But honestly?  Television consumption is a highly subjective experience and people have a lot of different tastes.  Just fiddle with the settings until you like what you see, because the picture settings that you like will be the right settings for you.
Samsung UE32K1500
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
While I agree that viewing is subjective, but if you don't know where to start, a site like tweak can help get the tv to a good place to start.
Stille (Desktop)
Evoo Gaming 15"
Used the tweaktv link here and it turned out pretty decent for being a diffrent tv. Did change some stuff but mostly kept it the same.
Cheers.
I have calibrated several TV and by far easiest and most beneficial thing you can do is to use the factory "movie" -preset.
In most cases the "movie" preset is very close to rec709.
If they are some image enhancement features turned on turn them off.
Here are test patters you'll only need the basic ones
http://www.avsforum.com/forum/139-display-calibration/948496-avs-hd-709-blu-ray-mp4-calibration.html#/topics/948496?_k=kgrayv
Instructions are displayed on each video.
Are you connecting devices to your TV?
Instead of using values from a Samsung c Series TV for a k-Series TV you could also use a dice to find your settings.
Yeah it'll be a 3rd monitor for my PC for some controller gaming (Rocket League etc) and blu ray playback from my PC. I'll also be connecting a Wii (through component) and a Wii U through HDMI to the TV too. I have downloaded the video files and will play them tomorrow on my PC and have a look. I understand the white and black level videos but what about the colour video?
You can set saturation and tint with it but a blue filter is required.
You could also check if your TV has a "blue only" mode.
You basically adjust saturation and tint until there's no flashing visible anymore.
IMO "blue only" mode only works on CRT displays but some people they otherwise.
