is it possible to turn my numpad to a soundboard?
KSores
Yep. Just use a program like this and bind the keys to your numpad.
https://sourceforge.net/projects/expsoundboard/
*Edit*
Fixed my spelling.
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
Just now, wrathoftheturkey said:
that's far from having a soundboard m8
more useful and the num pad is technically executing sounds.
*Edit*
Fixed my spelling.
i assigned it to the number 7 but it still typed a 7 along with the sound, how can i fix that?
That's just how it works. It doesn't cancel the typing with a soundboard.
You can probably use autohotkey to disable the keystrokes... Google around and see if AHK can help.
Stille (Desktop)
Evoo Gaming 15"
ok and 1 more thing, the sound is at a different pitch
I have no idea why that is... :P Never used soundboards, just know what they are. Sorry.
Stille (Desktop)
Evoo Gaming 15"
*Edit*
Fixed my spelling.
I downloaded it and added a few sounds are linked them to my numpad, but I can't get it to play for people on a discord with me.. I've messed around with different audio in/out stuff and can't get it to work. Any help would be awesome
insert aech tee em el here or something
So the reason why that is, is that soundboard is playing to your audio output... If you want it to play to Discord, you need to create a virtual audio interface that sits in between your mic and discord and daisy chain in the soundboard.
Not as hard as it sounds.
Stille (Desktop)
Evoo Gaming 15"
