Corsair ax series
My PC CPU: 2600K@4.5GHz 1.3v Cooler: Noctua NH-U12P SE2 MB: ASUS Maximus IV RAM: Kingston 1600MHz 8GB & Corsair 1600MHz 16GB GPU: 780Ti Storage: Samsung 850 Evo 500GB SSD, Samsung 830 256GB SSD, Kingston 128GB SSD, WD Black 1TB,WD Green 1TB. PSU: Corsair AX850 Case: CM HAF X. Optical drive: LG Bluray burner  MacBook Pro, Hackintosh
https://linustechtips.com/topic/70014-750w-fully-modular-psu/#findComment-959333
Seasonic X 750. Corsair RM 750.
https://linustechtips.com/topic/70014-750w-fully-modular-psu/#findComment-959334
Corsair RM Series.
My Pc: Cpu: I7 4790k @ 4,8 Ghz @1,25 volts, Motherboard: Maximus VII Formula, Graphicscard: 2x Titan X @1,4 at stock voltage (soon to be replaced), Ram: 32 gb Corsair Dominator Platinum 2133 Cl 9, SSD: 2x 850 Pro 1 Tb in Raid 0, 2x Samsung 840 Evo 1 tb raid 1,, PSU: Corsair HXi Series 1000W 80+ Platinum, Case: H440. Soon to be watercooled again, maybe, probably, the Titans are too loud.
https://linustechtips.com/topic/70014-750w-fully-modular-psu/#findComment-959345
[AMD Athlon 64 Mobile 4000+ Socket 754 | Gigabyte GA-K8NS Pro nForce3 | OCZ 2GB DDR PC3200 | Sapphire HD 3850 512MB AGP | 850 Evo | Seasonic 430W | Win XP/10]
https://linustechtips.com/topic/70014-750w-fully-modular-psu/#findComment-959356
XFX Pro 750W Black Edition Fully Modular (essentially a Seasonic model)
Folding@Home | BOINC
CPU: AMD Ryzen 9 3900X + Celsius S36 GPU: ASUS TUF RTX3080
MB: ASRock x470 Taichi RAM: Corsair Vengeance RGB DDR4-2666 32GB
CASE: Fractal Design Define 7 Panda STORAGE: WD Black SN770 2TB + WD Red Pro 6TB
https://linustechtips.com/topic/70014-750w-fully-modular-psu/#findComment-959376
Corsair AX760.
[Case] Phanteks Eclipse P400S TG (Air Mesh) || [CPU] Ryzen 7 5800X || [Cooler] Dark Rock Slim || [Mobo] ROG STRIX B550-F || [RAM] 32GB Trident Z RGB 3600MHz CL16
[GPU] XFX MERC319 Radeon RX 6950XT || [SSD] 1TB WD SN550 M.2 NVME || [HDD] 6TB Seagate IronWolf 7200 || [PSU] Corsair AX850
[Display] LG 27GL850 @ 2560x1440 - 144Hz || [Mouse] ROG Gladius II || [Keyboard] ROG Strix Flare (Cherry MX Red) || [Speakers] 2.1 Logitech Z-3 || [Fans] 6x 120mm Corsair LL RGB
Theater Room - My 11.1 Home Theater
https://linustechtips.com/topic/70014-750w-fully-modular-psu/#findComment-959396
