Is my i5 2500k and non-premium RAM Bottlenecking my system?
29 minutes ago, Sphio said:Monitor: Acer predator X34A
iI'll probably upgrade the 1060 to a 1080 or a 1080ti when it comes out in order to utilize the display properly.
With a 1060 no not really.... and your ram is definitely not a bottleneck. As long as you can run near 1600 you have plenty of through put on DDR3, its often easier to tighten timings on DDR3 than to overclock it as well. My old 1366 rig I could tighten my cas 9 sticks to cas 7 timings all day but the system absolutely would refuse to boot with ram in the 1800s. If anything you can attempt to tighten timings but as long as your sticks are 1600 Cas 9 or better you are plenty ok.
Your monitor should last you for years as a very nice setup I would suggest doing a completely new build in a year or two on the LGA 2066 platform when it comes out and when HBM2 becomes standard on GPUs and 3D X Point is hitting the mainstream market. Since you just picked up a 1060 recently which fits perfect with your 2500k I would say just wait and hold off for now unless your money is burning a hole in your pocket.
