Hello Everyone!
Ok so im looking to start a new build. The main focus of this build is going to be for After Effects, Adobe Premier, video editing and processing 4k  videos. I dont know much when it comes to picking the right hardware and need some tips. Best Buy has a computer for sale pre built. it includes,
amd fx black series,
rx 480,
8gb of ram,
1tb of hard drive space.
A friend suggested a different build but i have no clue which would be better for what im going to be doing.
His build was,
i5 4690k,
h50 water cooler
evga 750 ti,
hyper x fury 8gb of ram
I have no clue what to go with, i feel like the specs he recommended are better for gaming not really for what i need. Im working with a budget of 800-1000 usd. does anyone have any suggestions or tips? ill link best buys website down below.
Many thanks!
http://www.bestbuy.com/site/cyberpowerpc-gamer-ultra-desktop-amd-fx-black-edition-series-8gb-memory-amd-radeon-rx-480-1tb-hard-drive-black/5615010.p?skuId=5615010
https://linustechtips.com/topic/697882-pc-build-for-editing/
First thing's first. A 750 ti imo is kinda old. You may want something better for video editing. A gpu can make a lot of difference.
EDIT "Sorry I see your budget now. 800-1000USD. I'll try some things out. "
The best buy deal is only better because of the GPU that's better.
Get a second opinion and make sure I'm right about what I share.
Here's a video about gpus and videos.
https://linustechtips.com/topic/697882-pc-build-for-editing/#findComment-8930556
Well the build he suggested was trash, so Ignore it.
Why not build a PC, prebuilt are kinda effy.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/697882-pc-build-for-editing/#findComment-8930557
Just now, fpo said:
First thing's first. A 750 ti imo is kinda old. You may want something better for video editing. A gpu can make a lot of difference. Do you have a budget perhaps we can throw you a build together.
Thanks for the quick reply! i have a budget it cant be over 1000. id like to spend 800 and use 200 for a good monitor
https://linustechtips.com/topic/697882-pc-build-for-editing/#findComment-8930561
main purpose only for productivity? no gaming ?
G502 Lightspeed Review
PC:
i5-6400
GIGABYTE GA-H110M-DS2
CORSAIR VENGEANCE LPX 2X4 DDR4-2666MHz
ASUS ROG STRIX-GTX 1060-O6G
SEAGATE 2TB HDD
FUJISTU F300 240GB SSD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Logitech G310 Atlas Dawn (Romer G)
Rexus Legionare MX5.1 (Content Browns)
Mice:
Logitech G602
Logitech G502 Lightspeed
Steelseries Rival 105
Logitech M330
Headset:
Logitech G430
Cooler Master MH 752
https://linustechtips.com/topic/697882-pc-build-for-editing/#findComment-8930568
2 minutes ago, fpo said:
what do you think of this?
https://pcpartpicker.com/list/LzkFKZ
Do you have old hard drives? What old parts do you have?
I didn't include a case because I was hoping you had a spare. If not I can see what I can do with the budget.
It looks to be within budget i dont have a case but i can always add one to it this looks perfect. Do you think i would be able to run premiere and after effects fine with this setup or is there anything ill be missing out on? Thanks again i really appreciate the help
https://linustechtips.com/topic/697882-pc-build-for-editing/#findComment-8930590
PCPartPicker part list: https://pcpartpicker.com/list/D7ptKZ
Price breakdown by merchant: https://pcpartpicker.com/list/D7ptKZ/by_merchant/
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($299.99 @ Newegg)
CPU Cooler: Corsair H100i v2 70.7 CFM Liquid CPU Cooler  ($89.99 @ Newegg)
Motherboard: MSI Z170-A PRO ATX LGA1151 Motherboard  ($89.99 @ Newegg)
Memory: Avexir Core Series 8GB (1 x 8GB) DDR4-2400 Memory  ($41.99 @ Newegg)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($68.90 @ Amazon)
Video Card: Gigabyte Radeon RX 460 4GB WINDFORCE OC Video Card  ($95.98 @ Newegg)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case  ($69.99 @ NCIX US)
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($58.98 @ Newegg)
Total: $815.81
Generated by PCPartPicker 2016-11-27 04:54 EST-0500
I tried to make sure there were no compromises anywhere. It's obviously flexible on what you plan to do most on.
https://linustechtips.com/topic/697882-pc-build-for-editing/#findComment-8930592
Personally I don't have adobe software. However I left you an upgrade path. From what Linus and his team shares in videos about their PCs, a beefy cpu helps, but the video card is the a huuuuge boost. An eh cpu with a monster gpu will perform much better than a mega cpu. It was in one of their benchmarks. I believe the video I shared earlier but I'm not sure. sooo many ltt videos. I'm going to try another build modifying what I shared to see what I can do.
https://linustechtips.com/topic/697882-pc-build-for-editing/#findComment-8930605
Total: $815.81
Thanks a ton for your build suggestion whats your opinion between the 460 vs the 1060? i dont mind increasing it if ill get better performance and just wait for a better monitor later.
https://linustechtips.com/topic/697882-pc-build-for-editing/#findComment-8930608
do you have any spare GPUs?
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
https://linustechtips.com/topic/697882-pc-build-for-editing/#findComment-8930610
CPU: Intel Core i7-6700 3.4GHz Quad-Core Processor  ($294.99 @ SuperBiiz)
Motherboard: ASRock Z170A-X1/3.1 ATX LGA1151 Motherboard  ($60.98 @ Newegg)  Cheapest ATX LGA1151 Motherboard right now so don't say anything about how it's a z170 motherboard with a non-K CPU.
Memory: Team Elite Plus 16GB (2 x 8GB) DDR4-2133 Memory  ($69.99 @ Newegg)
Storage: ADATA Premier SP550 120GB 2.5" Solid State Drive  ($37.99 @ NCIX US)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($48.89 @ OutletPC)
Video Card: MSI Radeon RX 480 4GB GAMING X Video Card  ($179.99 @ Newegg)
Case: BitFenix Neos ATX Mid Tower Case  ($32.99 @ NCIX US)
Power Supply: Corsair CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($29.99 @ Newegg)
Total: $755.81
Generated by PCPartPicker 2016-11-27 05:01 EST-0500
This does include quite a lot of discounts...especially the RX480 so you know :P
Revised:
CPU Cooler: be quiet! Shadow Rock 2 51.4 CFM Rifle Bearing CPU Cooler  ($42.77 @ OutletPC)
Total: $852.47
Generated by PCPartPicker 2016-11-27 05:10 EST-0500
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
https://linustechtips.com/topic/697882-pc-build-for-editing/#findComment-8930619
gtx 1060 is wayyy better. The rx 460 is an amd card aimed at budget gaming. The 1060 is an nvidia gpu targetted more towards performance. Still working on a new build to see what I can beef up.
https://linustechtips.com/topic/697882-pc-build-for-editing/#findComment-8930625
The sort of specs or configurations here are good enough for 1080p editing, and may be able to handle 4K to a certain degree.  Working with 4K video requires, as a general rule of thumb, four times the resources of 1080p.  I personally would not (on a desktop build) work with less than a quad core, 16GB of memory and several TB of HDD/SSD storage space for 4K editing.  In fact, I'd have separate HDD/SSD setups (one dedicated for OS and Applications, another for project files).  After this, anything else depends on the kind of 4K and editing you are planning to work with.  Are you going to work with low bit rate 4K videos from cameras like a GoPro or high bit rate 4K videos from cinema cameras with huge file sizes, do you want to be able to color grade in wide gamut, high color depth, work with dozens of layers of video and audio tracks?
That is not dead which can eternal lie.  And with strange aeons even death may die. - The Call of Cthulhu
A university is not a "safe space". If you need a safe space, leave, go home, hug your teddy & suck your thumb until ready for university.  - Richard Dawkins
https://linustechtips.com/topic/697882-pc-build-for-editing/#findComment-8930626
Total: $755.81
The k version for that cpu is literally 5 extra dollars.
This makes sense, except you went cheapo on the PSU, and you leave very little storage for 4k video, 2tb minimum I say
Edit: nvm. the k version is out of stock
https://linustechtips.com/topic/697882-pc-build-for-editing/#findComment-8930631
i dont have any of the parts for it really it would have to be all purchased sorry if im making it hard to do within budget
how much storage do you need ?
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
https://linustechtips.com/topic/697882-pc-build-for-editing/#findComment-8930639
Didn't realise :P
Errmmmm...you know that the grey labeled CXM PSUs are higher than your NEX in quality right?
Total: $852.47
https://linustechtips.com/topic/697882-pc-build-for-editing/#findComment-8930645
Just now, Boxez408 said:
i feel like i would need to start of with at-least 2tb and i think i would be able to upgrade to ssd later for right now i dont mind using a regular hard drive.
thanks for that :) the ssd is eating up the budget ($119)
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
https://linustechtips.com/topic/697882-pc-build-for-editing/#findComment-8930646
1 minute ago, fpo said:
https://pcpartpicker.com/list/dkWxbj
Perhaps this?
Bit expensive but I'll try editing this list
He's not planning to game on it so the 1070 may be a lil useless :P
https://linustechtips.com/topic/697882-pc-build-for-editing/#findComment-8930655
1 last thing. how much would you go over 800?
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
https://linustechtips.com/topic/697882-pc-build-for-editing/#findComment-8930657
