2x4gb and 1x8gb in same system?
Solved by tomoki,
3 minutes ago, JoshPC said:Would any difference in performance be noticeable in games?
Well you did note in your first post that the speed is the same as your original pieces of RAM. The timing speeds of the pieces of RAM, if different, will run at the lower speeds but... you won't even notice it in real world performance when playing games.
If you have enough RAM to run your games right now, then the addition of RAM modules to your system won't make a difference other than the part where you won't have to close anything when you play games.
If you happen to know what RAM caching is, it could make your system a lot faster by using up the extra RAM.
