I can no longer see a bluetooth option in Device Manager. However, when I tried downloading and installing a new driver, I received a message that said that I already had the latest driver, thus a new one could not be installed. I'm not sure how to access this driver. Help?
https://linustechtips.com/topic/697159-bluetooth-driver-help/
What kinda adapter you are using? Is it integrated with mobo or USB? Laptop? The device might have been disconnected. So you need to remove it, replug and reboot. This will make Windows find it again and ask for drivers.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/697159-bluetooth-driver-help/#findComment-8925055
No adapter. I went off the assumption that my laptop came with Bluetooth capability, as that was quoted in the original build specs. I'm just trying to connect my wireless headphones to my laptop. If I do need an adapter, that information would be appreciated.
https://linustechtips.com/topic/697159-bluetooth-driver-help/#findComment-8934680
Laptop model? If you can't find Bluetooth in device manager, it might not have built-in. Also which OS are you running with?
https://linustechtips.com/topic/697159-bluetooth-driver-help/#findComment-8936511
XPS 15 9550. Also let me clarify my original statement: what I meant by not being able to see bluetooth in Device Manager anymore was that I tried to uninstall and reinstall the driver, but I'm pretty sure I screwed up in the process. Running Windows 10.
https://linustechtips.com/topic/697159-bluetooth-driver-help/#findComment-8945665
Thats odd. Device manager should show all devices which are active and connected. Can you access laptops BIOS and connect /disconnect bt from there? Another option is to repair OS.
https://linustechtips.com/topic/697159-bluetooth-driver-help/#findComment-8947394
Click the notification icon on the bottom right corner of the screen, turn bluetooth on. Click all settings and then go to devices>bluetooth.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/697159-bluetooth-driver-help/#findComment-8952243
