so i dont know anything about 3rd party CPU coolers and i would like some help deciding, it can be either water or air i have around £100. I don't have any clue about memory clearance but i do know that i DO NOT have LPS ram. My CPU socket is AM3+ and my case can support up to 240mm radiator or 155mm for the air coolers. Any help would be super cool
https://linustechtips.com/topic/696804-cpu-cooler-help/
if you arent doing a massive overclock maybe go for a hyper 212 evo and get a second fan to have a push and pull configuration
PC Specs:
CPU: Intel i9 12900K
CPU Cooler: Corsair Hydro H150i Elite Capellix
Mother Board: MSI z690 carbon WiFi
RAM: Corsair DDR5 6400MT/S
Storage: 2TB Samsung 970 Plus NVMe, 240 SanDisk SSD Plus, Crucial MX300 750GB SSD
GPU: Nvidia RTX 3090Ti FE
Case: Phanteks NV5
PSU: Corsair RM1000X
OS: Windows 11 Home
Monitor: Acer Predator XB271HU 27" 1440p @ 165hz
Keyboard: Razer Black Widow Chroma
Mouse: Logitech G502
Sound: Sony MDR 1000x Headphones, Blue Snowball Microphone
Laptop Specs:
Gigabyte Aorus 15G
CPU: Intel i7 10875H
RAM: 16gb DDR4
Storage: 512gb NVMe, 1TB Crucial MX300 SATA SSD
GPU: Nvidia RTX 2070 Max-Q
https://linustechtips.com/topic/696804-cpu-cooler-help/#findComment-8921363
im not doing any OC its just that my PC overheats and turns off  and i wanna solve the problem
https://linustechtips.com/topic/696804-cpu-cooler-help/#findComment-8921375
Then this cooler should be fine as my cpu which is over clocked doesn't go above 72 Celsius even when doing a stress test
PC Specs:
Case: Phanteks NV5
OS: Windows 11 Home
Laptop Specs:
Gigabyte Aorus 15G
RAM: 16gb DDR4
https://linustechtips.com/topic/696804-cpu-cooler-help/#findComment-8921397
22 hours ago, MrAwesomepants said:
Really? It's very popular in Norway
Last time I checked it wasn't available here or German stores. Seems like it has come here now. But with price of €46, its more expensive than both 212 Evo and Pure Rock. Making Pure Rock pretty much best cheap cooler with price tag of €39.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/696804-cpu-cooler-help/#findComment-8930859
