Where do I start.. Well, I'm a newbie to the whole water cooling thing, and never really thought about it until I seen Linus' "Ultimate Overkill Water Cooled Build" video. So, I am now interested in building a new computer to fit my gaming needs. I do not plan on water cooling this build until next summer, around August, so a year from now. I just want to get an idea of what I need to water cool my build. These are my spec's of the new build, and I need a part list for water-cooling it :) All help is much appreciated.
Specs: http://ca.pcpartpicker.com/p/1TC3G
https://linustechtips.com/topic/69659-water-cooling-this-build/
just plan your loop, then just get what you need from the interwebs. there are many,many videos showing how to set up a loop, just watch a few
CPU: i5 3570K @4.5GHz    GPU: R9 290   MOBO: ASUS p8z77-v  RAM: 8Gb corsair vengence   CASE: ARC MIDI  PSU: XFX pro 550W  HDD: 2tb segate baracuda
https://linustechtips.com/topic/69659-water-cooling-this-build/#findComment-954358
The thing is, I don't know the first place to look.
As _ASSASSIN_ mentioned you can look at the stickies on the LTT forums, something I'd recommend doing as well is looking for people who have done similar builds to yours either on google or here *cough* Define R4 *cough*  :ph34r:
https://linustechtips.com/topic/69659-water-cooling-this-build/#findComment-954448
I have already looked it up :/ Can't seem to find a good place to order from
https://linustechtips.com/topic/69659-water-cooling-this-build/#findComment-954537
Oh you mean ordering the components?
Assuming your name is not a lie and you are in fact from Canada I'd say NCIX, FrozenCPU and Dazmode are good places to start looking for components.
edit: If I remember this right there should also be a "where to buy" section in one of the stickies.
https://linustechtips.com/topic/69659-water-cooling-this-build/#findComment-954556
Here are 3 places i order my water cooling items from :
http://www.performance-pcs.com/catalog/index.php?main_page=index&zenid=f4b5af26c6612b1aa3ce968123bb61df
http://www.frozencpu.com/
http://www.aquatuning.us/index.php
Just look around. all the sites tend to have better or worse prices.
But like @For said NCIX and Dazmode are good also. I just found them a bit expensive.
Jacob Charles IV
https://linustechtips.com/topic/69659-water-cooling-this-build/#findComment-954584
Yes, I am Canadian. The one thing that's hard for me, and I am limited to very few sites to order from. You see, I need to order to P.O box, and most sites use something other than Canada Post, which is the only mailing service to provide support for P.O boxes.
https://linustechtips.com/topic/69659-water-cooling-this-build/#findComment-954590
Ah I see, sadly can't really help you with that since I live on the other side of the Atlantic.
https://linustechtips.com/topic/69659-water-cooling-this-build/#findComment-954596
well you got about 10months of time and many avenues of research to go by.
the pinned posts at the top of water cooling section are full of valuable information
on what you'll need, what components needed and this section of 10months of
topics to fill your knowledge void.
Watercooling FAQ - Some Basic Q&A
Water Cooling 101 - A good place for newbies to start
https://linustechtips.com/topic/69659-water-cooling-this-build/#findComment-955366
