Hi, I recently installed my second gtx1080 with a sli HB bridge from nvidia and with games like COD infinite warfare , rise of the tomb raider , Doom ... the graphics are bad with the sli config and i have also low gpu usage and low FPS v.s single gpu....???! (4K, 120 hz or 144 hz config)
I need help please ! Thank you.
Motherboard: Asus Maximus VI Hero ATX LGA1150
CPU: i7-4790K 4.0GHz
RAM: G.Skill Ripjaws X Series 32GB (4x 8GB)
Gpu: 2 nvidia gtx 1080 founders edition Sli
windows 8.1 pro
https://linustechtips.com/topic/695822-gtx-1080-sli-problem/
Did you enable SLI in the NV control panel ?
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/695822-gtx-1080-sli-problem/#findComment-8912892
What PSU is it?
Ryzen Ram Guide
https://linustechtips.com/topic/695822-gtx-1080-sli-problem/#findComment-8912934
How is CPU usage? Also is it the same in all games? Have you tried re-installing drivers?
Ryzen Ram Guide
https://linustechtips.com/topic/695822-gtx-1080-sli-problem/#findComment-8912955
Ok so I re-installed nvidia drivers and it works ! But only with the rise of tomb raider maybe because this game support sli and the others not ?  Thank you
https://linustechtips.com/topic/695822-gtx-1080-sli-problem/#findComment-8918427
CPU bottleneck would show as like 100% or 99% CPU usage across all cores with GPU lower. If you raise the resolution it works the GPU harder.
Ryzen Ram Guide
https://linustechtips.com/topic/695822-gtx-1080-sli-problem/#findComment-8927240
