Hello there, I would like to have your opinion on the best external drive that can both read and write CDs and DVDs
CPU: Intel Core i9-10900K  MOBO: ROG MAXIMUS XII FORMULA GPU: 2080ti Hall of Fame 10th anniversary limited edition  PSU: Asus ROG THOR 1200W  COOLER: Optimus foundation black acetal RADS: 3x EKWB CoolStream PE 360  LOOP: EKWB torque HDC fittings / EKWB ZMT 15,9/9,5mm / EKWB CryoFuel Clear MONITOR: Acer predator X34
https://linustechtips.com/topic/694802-best-external-drive/
that doesn't look external
https://linustechtips.com/topic/694802-best-external-drive/#findComment-8903355
https://www.amazon.com/LG-Electronics-Portable-External-GP65NB60/dp/B00ODDE33U/ref=sr_1_3?s=electronics&ie=UTF8&qid=1479835271&sr=1-3&keywords=external+cd+drive
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/694802-best-external-drive/#findComment-8903365
1 minute ago, SirFlamenco said:
Should have pointed out that I want it to be USB, I don't want to have to connect any SATA or any cable inside my pc.
https://linustechtips.com/topic/694802-best-external-drive/#findComment-8903367
I've had a few, and realistically as long as you get a quality brand name they're all the same.
You still burn CD's? Damn! Vintage.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/694802-best-external-drive/#findComment-8903393
https://linustechtips.com/topic/694802-best-external-drive/#findComment-8903395
