Hyperthreading might be disabled in the BIOS.
Come Bloody Angel
Break off your chains
And look what I've found in the dirt.
Pale battered body
Seems she was struggling
Something is wrong with this world.
Fierce Bloody Angel
The blood is on your hands
Why did you come to this world?
Everybody turns to dust.
The blood is on your hands.
The blood is on your hands!
Pyo.
https://linustechtips.com/topic/694517-not-hyperthreaded/#findComment-8900623
1 hour ago, SCGazelle said:
Could you give the exact model number of the CPU?
1 hour ago, Electronics Wizardy said:
What cpu, board, and os.
cpu is xeon e5 2666 v3 the board is Gigabyte x99 ud3p, and windows 10 64bit
https://linustechtips.com/topic/694517-not-hyperthreaded/#findComment-8900636
8 minutes ago, Marcus Torre DeProspero said:
So I have a supposed hyper threaded Xeon cpu its a E5 26xx series that is supposed to be 10 cores and 20 threads but it shows only 10 threads as well as cores any ideas on why it is doing this?
Check Windows Device Manager. You should see 20 logical processors.
https://linustechtips.com/topic/694517-not-hyperthreaded/#findComment-8900642
2 minutes ago, Marcus Torre DeProspero said:
yes but before it was perfectly fine and showed 20 but I haven't done anything
Thats your problem
Did you see it show 20, or was it the seller? THe seller may have shown a different chip.
https://linustechtips.com/topic/694517-not-hyperthreaded/#findComment-8900664
