Hey there, folks. I have what is probably a really stupid question that has always been a slight curiosity of mine. My laptop is a GS63VR, and it gets around three hours of battery life outside of gaming. Could disabling hyperthreading on the i7-6700HQ yield any tangible benefit in terms of battery life?
Thanks for reading my dumb question!
Current Build:
CPU: Ryzen 7 5800X3D
GPU: RTX 3080 Ti FE
RAM: 32GB G.Skill Trident Z CL16 3200 MHz
Mobo: Asus Tuf X570 Plus Wifi
CPU Cooler: NZXT Kraken X53
PSU: EVGA G6 Supernova 850
Case: NZXT S340 Elite
Current Laptop:
Model: Asus ROG Zephyrus G14
CPU: Ryzen 9 5900HS
GPU: RTX 3060
RAM: 16GB @3200 MHz
Old PC:
CPU: Intel i7 8700K @4.9 GHz/1.315v
Mobo: Asus Prime Z370-A
I would say no, because if the extra bits in the CPU for Hyperthreading aren't being used, it's probably going to be shut down. HyperThread does eat up more power if something is going on, but that's about it.
Plus you'd have to go into BIOS every time you wanted to switch it on/off
Probably would but you would have to factor in the performance you lose.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
It's not a dumb question, it's an interesting one imo. I think disabling cores could increase battery life, as could switching to your igpu (if you have one) but I'm not sure disabling threads would help.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
Nope, not at all, because hyper threading is disabled during normal use
He who asks is stupid for 5 minutes. He who does not ask, remains stupid. -Chinese proverb.
Those who know much are aware that they know little. - Slick roasting me
AXIOM
CPU- Intel i5-6500 GPU- EVGA 1060 6GB Motherboard- Gigabyte GA-H170-D3H RAM- 8GB HyperX DDR4-2133 PSU- EVGA GQ 650w HDD- OEM 750GB Seagate Case- NZXT S340 Mouse- Logitech Gaming g402 Keyboard-  Azio MGK1 Headset- HyperX Cloud Core
Offical first poster LTT V2.0
Yes, because more of the cores' resources are being used, thus higher power consumption.
Seeing a lot of mixed answers here o.O
I might just have to do my own test. Play a movie with HT on and off, and see what battery life is like. I'm not too worried about the performance loss, as the games I play don't even use more than four threads anyway. I have an SSD and my boot times are less than 10 seconds, so I'm not too worried about having to turn it back on in some cases.
Current Build:
GPU: RTX 3080 Ti FE
Current Laptop:
CPU: Ryzen 9 5900HS
GPU: RTX 3060
RAM: 16GB @3200 MHz
Old PC:
Here are some numbers with the 980X comparing hyper-threading on vs off. Bear in mind that the biggest difference is during CPU stressing with P95.
http://www.tomshardware.com/reviews/hyper-threading-core-i7-980x,2584-9.html
Also bear in mind that this is with an older CPU architecture :P
Can you switch over to the integrated GPU (HD 530 I believe) during non-intensive use? I believe switching over to that would make a bigger difference than hyper threading. In the NVidia Control Panel you should be able to see which programs use which GPU, or set your own depending on the program.
i5-6600K @ 4.5 GHz |I| Hyper 212 EVO |I| ASUS STRIX Z270E |I| 8 GB DDR4 HyperX FURY
GTX 1060 Windforce OC 6GB @ 2088 MHz
DEEPCOOL TESSERACT WH |I| EVGA 500 W1 80+
1TB 7200rpm HDD |I| 120GB SSD
GN246HL 144Hz 1080p
Corsair K70 LUX RGB |I| Corsair M65 Pro RGB
PCPP: https://ca.pcpartpicker.com/b/DHzYcf
I have auto-switching turned on. I'm just seeing what other gains are possible.
Current Build:
GPU: RTX 3080 Ti FE
Current Laptop:
CPU: Ryzen 9 5900HS
GPU: RTX 3060
RAM: 16GB @3200 MHz
Old PC:
On battery you can choose a TDP of 35w instead of 45w, just to let you know. That may help.
GN246HL 144Hz 1080p
So here is what I did. I downloaded a program that monitors battery discharge rate, as corrado33 suggested, and ran Cinebench with Hyperthreading and without. Each test was done after a restart, so only my usual background programs will be running alongside Cinebench and BatteryInfoView.
While running Cinebench:
Without Hyperthreading, the battery discharge rate stayed right around 52 watts.
With Hyperthreading enabled, the battery discharge rate increased to 62 watts.
While idle:
Without Hyperthreading, the battery discharge rate stayed around 14 watts.
With Hyperthreading, the battery discharge rate stayed around 28 watts.
So Hyperthreading increased power draw by roughly 16% under a full load, and doubled it at idle according to this program. I feel like I'm missing something here, because that's a massive difference in idle power draw.
(I heavily edited this post after I made it, because I realized I forgot to check idle power draw. Sorry.)
Current Build:
GPU: RTX 3080 Ti FE
Current Laptop:
CPU: Ryzen 9 5900HS
GPU: RTX 3060
RAM: 16GB @3200 MHz
Old PC:
10 minutes ago, Emberstone said:
While idle:
So Hyperthreading increased power draw by roughly 16% under a full load, and nearly doubled it at idle according to this program. I feel like I'm missing something here, because that's a massive difference in idle power draw.
What were your clock speeds without and with hyper-threading enabled? What about CPU voltage?
I think I figured out the culprit. The Battle.Net client. With Hyperthreading enabled, it was taking up more CPU than many of my background processes, keeping the clock speeds well above idle.
Without Hyperthreading enabled, my clock speeds would hover from 1.0 to 2.0 GHz, but after enabling it the clocks stayed well above 3.0 GHz the entire time. As soon as I closed out of BNet, the clocks then mirrored my non-Hyperthreaded clocks of 1.0 to 2.0 GHz. The BNet client loves its threads I guess. The voltage then went down to around 0.8 to 1 volt or so.
With BNet now closed, the idle power draw both with Hyperthreading enabled and without was about 14 watts (just in case this isn't clear, I tested both HT on and off without BNet open). I wouldn't have run into this problem if I just did a clean boot, but I'm lazy and I kind of wanted these tests to simulate a realistic scenario.
So that means the only real factor in battery life here for the i7-6700HQ is the power draw under load, and Libre Office sure as hell isn't going to max out this processor while I'm taking notes in class.
Thanks for telling me to check clock speeds!
Current Build:
GPU: RTX 3080 Ti FE
Current Laptop:
CPU: Ryzen 9 5900HS
GPU: RTX 3060
RAM: 16GB @3200 MHz
Old PC:
