Problems with storage device not booting into Windows
I had my computer working completely before any of this happened by the way. So I was asked my my cousin to try and recover some data off a old hard drive so i pluced it in and all I got was a Windows repair thing and when I did that nothing happened and I tried it twice and let Windows repair do its thing nothing happened. So I decided to just plug my original hard drive back in and I keep getting this message and I'm not sure what happened. I'll also tske a picture  my PC parts list and send a picture of the old hard drive.  Can anyone help me out? Http://pcpartpicker.com/list/wblLXPs
Go into the BIOS and make sure the drive is detected first.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
3 minutes ago, deXxterlab97 said:
Question is: why would someone print out a pcpartpicker link and then take a photo of it so that later you can insert the link properly to the post
Check if there could be cable lose or broken?
I tried the link and it was broken and the paper is old so I used that instead and the drive is detected in the bios I'll check all the cables
And you've checked your boot sequence within the BIOS to make sure the HDD is listed right?
There are multiple reasons for this check through this list
If windows was previously installed: windows requires certain files to boot and without those files the Hard drive becomes non bootable, If you have installed a virus, some will delete vital files in the system32 folder which may have rendered the hard drive non bootable. if there are files you require, I would use a live cd of linux to check the harddrive, as well as this I would use the live cd to get any files that are required. after this, format the hard drive and reinstall windows
If windows wasnt installed: you need to make a bootable usb of the windows you wish to install, you can do this with windows 10 by using another pc and use the USB installer, then insert the drive and the USB into the PC and use the bios to set the USB as the main boot device, then restart and install windows. then when it is installed go to the bios and change the boot sequence back to the hard drive
Main PC | AMD R7 3700X | Noctua D14 | MSI RTX 2080 Super XS OC | Corsair Vengence LPX 32GB DDR4 3200MHz | MSI B550A Pro | 1TB PNY XLR8 NVMe SSD | Kingston A400 960GB SSD | 2TB Western Digital Green HDD | Fractal Design Define R6TG |
Laptop (Asus TUF FX505DY) | AMD R5 3550H | RX560X | Crucial DDR4 16GB 2400MHz | Western Digital SN550 256GB SSD | PNY CS900 960GB SSD |
Phone | Samsung S10 Lite (128GB + 128GB SD card) |
Other Cool Stuff | Steam Link | Sontronics Podcast Pro | NZXT Hue+ | Corsair K70 MK 2 (MX Brown) | Logitech G402 | HiSense A7300 43 Inch 4K TV | Logitech C920 | Ender 3 Pro with Bulleye Fan duct and BLTouch |Sony PS4 | Nintendo Switch
This is the order it's in I'm not sure what UEFI means though since there's also one in the boot order that doesn't say that it just says "hard disk"
