Please help
Go to solution Solved by VinZie,
Just now, Sulfurplaysgames said:
I'm starting to think either my power supply is losing power or something else.
I would also try a new power supply. When my brother, and I worked on my server build we got the same issue. We changed the PSU, and fixed.
Hi guys I just finished my new computer build. I'm at the point where I need to install windows but as I insert the USB drive and boot into it my computer will shut off instantly with a black screen. Any ideas?
EDIT: the internals will still be powered but I have a black screen.
https://linustechtips.com/topic/691472-please-help/#findComment-8868720
Yes I have the USB as the first boot priority. I get to the start screen to start installing windows and then it just black screens me
no Blue screen of death? - the monitor just cuts out? Be more descriptive - does the monitor just cut out or does the entire computer die - if it's not that - which parts stop running - send a parts list too and a picture of the inside of ur comp
https://linustechtips.com/topic/691472-please-help/#findComment-8868782
Got power cable connected to the graphics card?
                  Did I help you to fix your problem or at least did offer somewhat valuable advice? Consider giving my post a "informative" or "thumbs up".
SYSTEM 2: Modded G3 case with Gigabyte GA-G33M-S2L, Intel E8600 (O.C to 4.2GHz.), 4GB GSkill PC8500, Nvidia 8800GTS (512M), Cooling provided by Scythe Big Shrunkin, HDD 1 = OSX 10.9.5, HDD 2 = Windows 7 Pro X64. (Placed 3rd in MacMod  of the year 2012) (For info see:  http://insanelymac.com/forum/topic/285641-and-the-winner-for-macmod-of-2012-is/
LAPTOP: Inspiron 1720, Modded BIOS, X9000 Core 2 extreme OC'ed and undervolted to 3.4GHz (windows only) , 6GB DDR2 800, 8600M GT, 1920x1200 Glossy display, Sigmatel Audio, 2 Kingston HyperX 120GB drives (1 with Windows 7 x64 pro & 1 with OSX 10.9.5) X9000 Processor World Record Holder since 02/2013 on Geekbench 2 : http://browser.primatelabs.com/geekbench2/search?dir=desc&q=x9000&sort=score
https://linustechtips.com/topic/691472-please-help/#findComment-8868788
The screen will just cut out but everything will still be powered on within my case.
Parts
i7-4790k
cm hyper 212 evo
msi z97 gaming 5
Gtx 1070
evga 650w g2 psu
4x hyper x 4gig sticks (2 new 2 reused)
kingston 120gb ssd
wd 1tb blue
https://linustechtips.com/topic/691472-please-help/#findComment-8868795
Parts
i7-4790k
cm hyper 212 evo
msi z97 gaming 5
Gtx 1070
evga 650w g2 psu
kingston 120gb ssd
wd 1tb blue
Does the monitor shutoff??
https://linustechtips.com/topic/691472-please-help/#findComment-8868799
Parts
i7-4790k
cm hyper 212 evo
msi z97 gaming 5
Gtx 1070
evga 650w g2 psu
kingston 120gb ssd
wd 1tb blue
the gpu fans are on, the cpu cooler is on, only the screen cuts out nothing else?
https://linustechtips.com/topic/691472-please-help/#findComment-8868802
https://linustechtips.com/topic/691472-please-help/#findComment-8868805
1 minute ago, Sulfurplaysgames said:
Removes the two old ones and still same results. I get the debug code 31 which is early CPU initialization after the screen blacks out.
https://linustechtips.com/topic/691472-please-help/#findComment-8868915
https://linustechtips.com/topic/691472-please-help/#findComment-8868924
