Hello, everyone. I've found myself in a pickle.
So today, I got this video card for my PC:
https://www.amazon.com/dp/B01I5O5AP2/?tag=linus21-20&th=1
I opened it up, and found this little guy in the box when I pulled out the card. A photo is included with this post of it, it's like a little black rectangle. Another picture included will show where it looks like it might have come off.
So anyway, I plugged it into my PC and booted it up. Everything turned on, including the card, and at first I connected to the new video card.
Originally I was running on integrated graphics, so this is my first video card.
the monitor wouldn't receive any signals, also the keyboard wouldn't turn on. For some reason, the mouse did though.
so now, I feel like I've tried everything. I just don't know what the problem is. Please don't let my mother board be shot, this would be the second one I've had to replace.
ANY RESPONSE APPRECIATED
https://linustechtips.com/topic/691407-desperately-need-help/
Did you break it? If not, could you return it back to amazon as DOA or something?
Was I helpful? Accept my answer or agree / mark me as informative!
Quote me, or I probably won't notice you responded to me!
Only Constructive Criticism is taken into consideration.
https://linustechtips.com/topic/691407-desperately-need-help/#findComment-8867968
1) you plugged your GPU into a PC when it was obviously missing a component?? WHY???
2) did you try using integrated graphics again instead of the GPU?
3) why would it be your motherboard? what does your motherboard have to do with any of this? I thought you're talking about your GPU?
https://linustechtips.com/topic/691407-desperately-need-help/#findComment-8867985
1. I looked it up, and mistakenly read that it might be a transistor which apparently doesn't matter very much if lost, so that's why I tried plugging it back in.
2. Yes, I did try. Nothing happened, but the PC still turned on. The monitor and keyboard still didn't work.
3. I though maybe the graphics card could kill the mobo if plugged in. I'm pretty scared right now.
https://linustechtips.com/topic/691407-desperately-need-help/#findComment-8868067
So you thought the GPU can kill the motherboard, and you still plugged it in??
Btw that's not a transistor.
https://linustechtips.com/topic/691407-desperately-need-help/#findComment-8868083
4 minutes ago, BraytonH said:
No, I thought that after do all of this.
Do you know why my monitor wouldn't be working?
Have you tested it with a different PC?
https://linustechtips.com/topic/691407-desperately-need-help/#findComment-8868159
Just now, BraytonH said:
No, but I did try my PC with a VGA monitor and nothing showed up. I was using my PC perfectly fine earlier, until I tried using the card.
Well it definitely looks like the card damaged something.
The only way to find out what is trial and error, test the screen with a different PC, or test a different screen, etc...
https://linustechtips.com/topic/691407-desperately-need-help/#findComment-8868194
Oh my goodness, this is awful news. What should I even do? I can't afford to get any new parts and I need this PC.
https://linustechtips.com/topic/691407-desperately-need-help/#findComment-8868283
Just rma the card, you should have done this in the first place when you saw the damage.
Current LTT F@H Rank: 24    Score: 10,097,484,643   Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
Cooler: Noctua NH-D15
Mobo: Asus ProArt X670E Creator WiFi
RAM: 96GB Trident Z Neo @6400 CL32
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 990 Pro 4TB NVME, Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
Cooler: Noctua NH-U9S
Mobo: Asus ROG Strix X470-F
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
PSU: EVGA G3 850W
Total Storage: Raw: 94TB, Usable: 64TB
SSD: Samsung 990 Pro 2TB NVME, Teamgroup 4TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (7x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
https://linustechtips.com/topic/691407-desperately-need-help/#findComment-8868975
No you see, I noticed the damage after I realized the card wasn't working and thought to myself of the possibility of my motherboard being shorted out by the faulty card.
https://linustechtips.com/topic/691407-desperately-need-help/#findComment-8869768
