PS4 pro help
By
Wolf ~ IRONI
in Console Gaming
in Console Gaming
Solved by pwn_intended,
^ Don't listen to dicks like that. Play on whatever system you want man.
As far as what you can hook it up to, any monitor/tv that accepts an HDMI signal will work.
AFAIK the only mic's you can use with a ps4 have to be plugged into the controller itself (so pretty much any phone headset works) USB will not though.
kerriya ·
Posted in Cases and Mods4 -
octester ·
Posted in Troubleshooting5 -
DavidPatrascu ·
Posted in General Discussion7 -
2
3
bill well ·
Posted in Peripherals1 -
4
2
Ha-Satan ·
Posted in Networking3
play_circle_filled
Latest From ShortCircuit:
