Hello people,
I am planning to build a Everyday use PC for my mom as a Christmas gift.
Her everyday uses are Netflix, Skype, and checking emails. Nothing else.
I think I do not even need a dedicated gpu, on board graphics should be fine, am i right?
Please give me some suggestions on doing this build.
Budget: As much as it needs to get the daily tasks done.
Thanks
https://linustechtips.com/topic/690754-everyday-use-pc-building-suggestions/
CPU: AMD Athlon II X2 240 2.8GHz Dual-Core OEM/Tray Processor  ($29.94 @ Amazon)
CPU Cooler: Cooler Master Hyper T2 54.8 CFM Sleeve Bearing CPU Cooler  ($6.99 @ Newegg)
Motherboard: Asus M5A78L-M/USB3 Micro ATX AM3+ Motherboard  ($36.98 @ Newegg)
Memory: Avexir Budget Series 4GB (1 x 4GB) DDR3-1333 Memory  ($19.89 @ OutletPC)
Storage: Western Digital Caviar Blue 320GB 3.5" 7200RPM Internal Hard Drive  ($19.99 @ Amazon)
Case: Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case  ($24.99 @ SuperBiiz)
Power Supply: Corsair Builder 500W 80+ Bronze Certified ATX Power Supply  ($29.99 @ Newegg)
Total: $168.77
Generated by PCPartPicker 2016-11-14 11:10 EST-0500
Total: $168.77
i would say go with a 128gb ssd for like 10-15 bucks more.
makes the whole pc expirience 10x better
12 minutes ago, dreamhacking said:
as much as it gets the build done properly to do those daily tasks. Thanks
I would suggest a quad core APU build. my parents have a 1st gen APU from long ago, still no hiccups (even with Norton installed)
6600K - ASUS Z270i Gaming ITX - 8GB Corsair  Vengence LPX DDR4 2400MHZ - EVGA 1070SC - 120GB HyperX Savage SSD - CX430 PSU:|
PSU tier list-
I'd suggest:
AMD A6 or A8 APU
basic motherboard (FM2+)
8 Gigs (2x4) of DDR3-1866
120-250Gig SSD (no HDD)
Corsair CX450M or similar power supply (if a PSU is not included in the case)
Whatever case you like
If it was me, I'd go for some sort of very small ITX case - with an APU you don't need a discrete graphics card.
Btw, the graphics portion of the APU is better than the IGP in an Intel CPU, and therefore, better for Skype, etc.
My wife uses an A8-7600 with just a single 120Gig SSD. Works just fine. :)
A sieve may not hold water, but it will hold another sieve.
i5-6600, 16Gigs, ITX Corsair 250D, R9 390, 120Gig M.2 boot, 500Gig SATA SSD, no HDD
6 minutes ago, TheNuzziNuzz said:
THis is a little more than you need, but its worth a look:
http://pcpartpicker.com/list/9zfYr7
His mother won't use anywhere near that much of storage and an i3 is not needed at all. I am not sure if she need IPS too and why Z170 mobo on a non K cpu?
Here is one with APU
CPU: AMD A4-6300 3.7GHz Dual-Core Processor  ($31.98 @ Newegg)
Motherboard: Biostar Hi-Fi A70U3P Micro ATX FM2+ Motherboard  ($31.98 @ Newegg)
Total: $158.82
Generated by PCPartPicker 2016-11-14 11:31 EST-0500
6 minutes ago, dreamhacking said:
is that something like A6-7400K?
yea but if you can splurge for a A8-10
PSU tier list-
Here's a nice case which uses an SFX power supply:
http://www.ncix.com/detail/silverstone-sst-ml05b-mini-itx-4x2-5in-2xusb-8c-86320.htm
Just now, dreamhacking said:
Thanks guys.
Looks like AMD APU will be a solid choice right? at least better than Intel on board graphics.
Yes, APU makes really goo integrated gpu. Only consider if going for Skylake which is most likely too much
3 minutes ago, dreamhacking said:
Thanks a small case like that is needed too haha
Hmm, been looking at the price of SFX supplies .....
300watts should be enough:
http://www.ncix.com/detail/silverstone-sfx-series-300w-atx-9c-93203.htm
i would not consider skylake i3, that is overkill.
only maybe the Skylake Pentium G4400
High quality components with potential to upgrade. A smaller case and cheaper PSU can be added.
http://pcpartpicker.com/list/xz4fhq
i5-6600k (4.6) | Dark Rock 3 | MSI GAMING X 1060 6GB | 8GB DDR4 | 120GB SSD & 1TB HDD | Crystal 460x
 | Acer GN246HL 1080p 24" 144hz & Acer G246HL 1080p 24" 60hz |
PSU Tier List | PC Partpickers: US Canada Australia UK
23 hours ago, dreamhacking said:
A6-7400K or A8-7600?
$30 CAD difference, is it worth the money? (other than it has better integrated graphics)
I'd say that the A8 is worth the extra money. It has "R7" graphics rather than the A6's "R5" plus it has more "cores".
That would make Skype, HD Youtube videos, Netfix, etc, work smoother.
