Hey, I made a post a few days ago about the same issue, but now things have changed. I have a laptop with an i7 4700mq, an nvidia gt 740m and 8GB RAM. I said that I was having ridiculously low FPS in every game I played on my nvidia gt740m GPU. A few months ago I replaced the thermal paste and cleaned the fan with isopropyl alcohol 99.9% and the fan was as new and I was getting good temps, but now the gpu was reaching 105ºC. A couple days ago I reopened my laptop and noticed the fan wasn't very dirty at all, cleaned the fan, the heatsink and those exhaust metal blades (which I never did before) and the gpu temperatures dropped from 105ºC to 85ºC maximum and now I'm able to play most games I couldn't before but not as good as I used to play and that may be because of some previous overclock I did before so basically I've got a degraded nvidia GPU. I know these GPU's are soldered to the motherboard and I know it is possible to resolder a new gt 740m, but where can I get a replacement one? Is it possible to replace it with a different gt 7xxm? Also, is the thermal paste supposed to be like that after 2 months? image
Many thanks.
Quote me so I can reply back :)
MY PC-> PSU: EVGA SuperNOVA T2 1000W 80 Plus Titanium MOTHERBOARD: ASUS X370 Crosshair VI Hero CPU: RYZEN 7 3700X RAM: G.Skill 32GB (4X8GB) DDR4 3200MHz C14 GPU: EVGA GTX 1080Ti FTW3 HYBRID STORAGE: Samsung 970 EVO 500GB NVMe SSD; 2TB WD Caviar Blue; Crucial MX500 500GB SSD CUSTOM LOOP: EK-Velocity Nickel + Plexi CPU block, EK-FC1080 GTX Ti Acetal + Nickel GPU Block w/ EK-FC1080 GTX Ti Backplate, EK-XRES 140 Revo D5 PWM, EK-CoolStream PE 240 w/ 2x Noctua NF-F12 Chromax fans, EK-ACF Fitting 10/13mm Nickel, Mayhems UV White tubing 13/10mm, 3x Noctua NF-S12A Chromax case fans
https://linustechtips.com/topic/690249-nvidia-gt-740m-low-fps/
1 minute ago, Thread212 said:
What thermal paste u are using? because that one looks expired.
Dont put to many on it.
for a laptop all u need is a one grain of corn.
740m is a low end gpu, overclocking it just..it will help but its better just to upgrade your laptop.
Or built a pc. and on top of that. its a laptop.
Overclock need a good heatsink. and basically u are trying to overclock a cpu with a stock heatsink only its a gpu.
I dont think u can replace it by yourself. unless u are good.
Just go to ebay or craiglist and see if u can find a broken laptop with 740m gpu.
The thing is, i'm trying to find a "cheap" solution to play a few games better. I'm not going to build a computer just now, because soon I will have no use for it as I'll finish school and will have to work. but anyway, when replacing the gpu, does it have to be a gt 740m?  or maybe it could be a 745m?
https://linustechtips.com/topic/690249-nvidia-gt-740m-low-fps/#findComment-8854831
get a used console
-----> Official Unofficial Favorite Keyswitch Type Survey <-----
 OWNER OF THE FASTEST INTEL iGPU ON LTT UNIGINE SUPERPOSITION [lol]
GAMING RIG "SNOWBLIND"
CPU i5-13600k | COOLING Corsair H150i Elite Capellix 360mm (White) | MOTHERBOARD Gigabyte Z690 Aero G DDR4 | GPU Gigabyte RTX 3070 Vision OC (White) | RAM  16GB Corsair Vengeance Pro RGB (White)SSD Samsung 980 Pro 1TB | PSU ASUS STRIX 850W (White)CASE  Phanteks G360a (White) | HEADPHONES  Beyerdynamic DT990 Pro | KEYBOARD Zoom75 (KTT Strawberry w/ GMK British Racing Green keycaps) | MOUSE  Cooler Master MM711 (White) MONITOR HP X32 1440p 165hz IPS
WORK RIG "OVERPRICED BRICK"
Mac Studio (M2 Ultra / 128GB / 1TB) | HEADPHONES  AirPods Pro 2 | KEYBOARD Logitech MX Mechanical Mini | MOUSE  Logitech MX Master 3S MONITOR 2x Dell 4K 32"
SECONDARY RIG "ALCATRAZ"
CPU i7-4770K OC @ 4.3GHz | COOLING Cryorig M9i (review| MOTHERBOARD ASUS Z87-PROGPU Gigabyte 1650 Super Windforce OC | RAM  16GB Crucial Ballistix Sport DDR3 1600 MHzSSD Samsung 860 Evo 512GB | HDD Toshiba 3TB 7200RPMPSU EVGA SuperNOVA NEX 750WCASE  NZXT H230 | HEADPHONES  Sony WH-1000XM3  | KEYBOARD Corsair STRAFE - Cherry MX Brown | MOUSE  Logitech G602 MONITOR LG 34UM58-P 34" Ultrawide
HOLA NIGHT THEMERS
GET YOUR ASS ON NIGHT THEME
OTHER TECH I OWN:
MacBook Pro 16" [M1 Pro/32GB/1TB] | 2022 Volkswagen GTI | iPhone 14 Pro | Sony a6000 | Apple Watch Series 8 45mm | 2018 MBP 15" | Lenovo Flex 3 [i7-5500U, HD5500 (fastest on the forum), 8GB RAM, 256GB Samsung 840 Evo] | PS5, Xbox One & Nintendo Switch [Home Theater setup] | DJI Phantom 3 Standard | AirPods 2 | Jaybird Freedom (two pairs) & X2 [long story, PM if you want to know why I have 3 pairs of Jaybirds]
https://linustechtips.com/topic/690249-nvidia-gt-740m-low-fps/#findComment-8854875
Just now, Thread212 said:
ps3
XB360 is better tho
lmao jk whichever is cheaper. It'll cost less than a new 740M if you could even find one
HOLA NIGHT THEMERS
OTHER TECH I OWN:
https://linustechtips.com/topic/690249-nvidia-gt-740m-low-fps/#findComment-8854898
