HD7970 second hand temps
Go to solution Solved by RadiatingLight,
Just now, Spasi said:
Hello, i bought a HD7970 Sapphire Dual-x second hand.
As soon as i got it i changed the TIM. But with stock settings and stock bios at 925mhz and 1.175v i have max temp 76C in heaven.
Are those temps ok ? When i underclock it to 900mhz and undervolt to 1020v temps never reach higher than 60C.
Temps under 80-85c are OK
personally, I am willing to push my GPU to 90c, but that's just because I'm careless
those temps are fine
https://linustechtips.com/topic/689373-hd7970-second-hand-temps/
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/689373-hd7970-second-hand-temps/#findComment-8846126
My Sapphire Dual-X 7970 usually sits around 85 at stock, but one of the fans is broken.
GAMING PC "Ol' Bessie":
Ryzen 7 7800X3D | Radeon RX 9070 XT | Gigabyte B650M AORUS Elite AX | G.Skill Flare X5 6000MT/s CL36 16GBx2 | 5TB of SSD POWER | EVGA SuperNOVA 850W GT | Noctua NH-U14S | Fractal Design Pop! Mini AirCachyOS
Kind Of A Home Lab "Bay":
Ryzen 9 5900XT | Intel ARC A310 | ASUS PRIME B550-PLUS | T-FORCE 3200MT/s 16GBx2 + Corsair 3200MT/s 32GBx2 = 96GB!!! WOW!! | 2TB boot SSD + 8TBx6 HDD RaidZ2 | EVGA SuperNOVA 650W G2 | Phanteks Enthoo Pro M | Ubuntu 24.04 LTS
The Laptop:
Framework Laptop 13 | Intel i5-1340p | G.Skill Ripjaws 3200MT/s 16GBx2 | Solidigm P44 Pro 2TB | CachyOS
https://linustechtips.com/topic/689373-hd7970-second-hand-temps/#findComment-8846148
