FreeNAS does not support 32bit CPUs. You need a CPU that support 64bit in order to use FreeNAS. What hardware you running FreeNAS on?
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
https://linustechtips.com/topic/689296-freenas-problems/#findComment-8845540
I highly advise against running FreeNAS on 32bit hardware, let alone an intel Atom.
Even if you had gotten FreeNAS running on 32bit, you would not be able to use ZFS as it inherently doesn't not support 32bit.
If you have read over the FreeNAS minimum requirement, you would of noticed that you should have a recommended minimum of 8GB.
I would recommend Nas4Free. It has a min requirement of 4GB and is similar to FreeNAS.
If you're looking to try FreeNAS in this manner, the best way to do it is by running it in a VM.
https://linustechtips.com/topic/689296-freenas-problems/#findComment-8858952
If you  still want to use freenas I recommend the asrock c2550d4i or the asrock c2750d4i motherboard if you're going do use it as a plexserver or run some VMs.
I have the 2750 and it works great, and it has 12 SATA ports on a mini ITX board! And it Suppports ECC memory.
unRAID 6.3.5 Plus | CASE: Fractal Define R5 | MOBO: Supermicro X9DRL-iF | MEMORY: Samsung ECC REG 64GB 8x8GB | CPU: 2 x XEON E5-2670v1 | PSU: Corsair RM850x 850W | DRIVES: 1 x Seagate Ironwolf 8TB [Parity drive] 2 x Seagate Ironwolf 4TB [Data drives] 4 x WD Red 4TB NAS Harddrive [Data drives] | CACHE: 2 x Crucial MX300 275GB SSD [Cache drives in RAID1] | 1 x HyperX Fury 120GB 2.5" SSD [Plex drive] | OS drive: Kingston Datatraveler SE9 16GB USB drive
https://technicalramblings.com/
https://linustechtips.com/topic/689296-freenas-problems/#findComment-8866745
