Hello everyone !
I'm thinking about buying a computer and I made some research and created on " pcpartpicker.com ", thing is, I'm not quite sure if it's a bit too much or not enought. I mostly do gaming and few editing + a lot of multitasking, all of that one a UltraWide screen, I want games to run on Max setting for most of them with more than 120 fps ( Picked a 144hz monitor dedicated for that )
http://pcpartpicker.com/list/H3297h
The website is confirming that there is no compatibility issue, but I wonder if the Wattage will be enough or even if the case will allow me to upgrade further.
Thanks for taking time to check it :)
https://linustechtips.com/topic/686777-new-build-need-help-and-tips/
Are you sure you want to deal with a 35" 2560*1080p monitor? The resolution seems too low for its size.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
Power supply is crap and the fans for that cooler are suuuper loud.
1 minute ago, Thread212 said:
Everything is good except the SLI configuration,the power supply and the monitor.
I recommend EVGA G2 for the power supply or super flower leadex.
And what are u going to do with dual 1070?
As for the monitor i will buy 1440p 144hz IPS panel if u are going to use SLI.
I quite like good quality on games and like, a dual 1070 should bring enough power into most of the games I play
Regarding screen, Why not a widescreen for SLI,  I won't requiere SLI if I go for 1440p 144hz, do I ?
Why is it crap ? And loud :o ? Did you have some ?
Just now, Thread212 said:
NEC psu are not that crappy actually but its just not good for the price.
I recommend either g2 supernova series or leadex series.
Yes thats why i recommend 1440p 144hz ips panel no matter its widescreen or not.
because with IPS you will get more vibrant and detailed color compared to TN panel.
I understand regarding the PSU, will look into what you advised me and for the screen I really want an immersive screen so I can only focus on the game explaining why I want ultrawide, And TN helps regarding FPS If I'm right, even tho screen is already on 144hz, I'm also wondering if a 120 HZ wouldn't be better with IPS
A 1080 beats two 1070's... Why not just a 1080? Then when you wanna upgrade just buy another 1080.
CPU : i7 4790K // GPU: MSI 980Ti 6G // CPU Cooler: LEPA AquaChanger 240 // MOBO: Gigabyte GA-Z97X-SLI // RAM: 16GB HyperX Fury @ 1866 //    Case & PSU // Fractal Define S & EVGA 750W
51 minutes ago, Thread212 said:
Generally For gaming u dont need more than 60Hz. but for a competitive games like CS GO or Dota Or LOL.
especially FPS games above 60Hz will help.
Ultra wide 35 Inch 1080p monitor wont give u a immersive experience at all.
the resolution is too small for the Screen Size.
Why dont u just buy 144hz 1440p ips with G-sync instead??
I actually play some MMO / FPS / TPS that requiere a lot of FPS to maintain a good skill and or so, be competitive, when you speak about the resolution to small for the screen, does that mean that there will be some black borders ?
And ye,  I was thinking about one of those 144hz 1440p ips with gsync, seems good for a GTX, actually the Rog Swift from Asus ( 34 inches ) looks quite interesting
Edit: Sorry for late answer, didn't refresh the page
No.. thats called aspect ratio..
most monitor today comes with standard 16:9 aspect ratio.
There will be no black border, but its just like when u are printing 720p image in 5x3 meters paper or something.
Ah, I get it, the pixels won't be that great, so ye I should go for the Rog Swift, same price but better quality
