Heyo my friend recently is wanting to upgrade his system to something a little more powerful then what he has now
His Specs atm (quick note all prices are in CAD)
  1. FX 8320
  2. Asus m5a97 r2.0
  3. Gigabyte Windforce GTX 770 2Gb
  4. Kingston fury X 8GB
  5. random 550W power supply
  6. seagate 1TB 2.5inch HDD
What he is looking at buying
  1. NZXT S340 $89.99 (http://tinyurl.com/jhb5yx6)
  2. Gigabyte G1 Gaming 3 H170 $101.99 (http://tinyurl.com/jczpadq)
  3. Intel I3 6100 $152.99 (http://tinyurl.com/jravg4g)
  4. Geil Evo 8GB $47.99 (http://tinyurl.com/hn2kazy)
  5. Sama Armor 550 $89.99 (http://tinyurl.com/h5w2ys6)
He wants to upgrade his storage and gpu later so the total with tax and shipping is $584.35
https://linustechtips.com/topic/686014-upgrading-friends-system/
Save up for a i5-6400 and get a namebrand PSU (they will cost the same or less) the Corsair CX 550m (with the grey label) is a good choice.
i5-6600k (4.6) | Dark Rock 3 | MSI GAMING X 1060 6GB | 8GB DDR4 | 120GB SSD & 1TB HDD | Crystal 460x
 | Acer GN246HL 1080p 24" 144hz & Acer G246HL 1080p 24" 60hz |
PSU Tier List | PC Partpickers: US Canada Australia UK
https://linustechtips.com/topic/686014-upgrading-friends-system/#findComment-8810343
That's not much of an upgrade at all.
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($260.74 @ Vuugo)
Motherboard: ASRock H110M-DGS Micro ATX LGA1151 Motherboard  ($43.98 @ NCIX)
Memory: G.Skill Aegis 8GB (1 x 8GB) DDR4-2133 Memory  ($44.99 @ Newegg Canada)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($89.99 @ Newegg Canada)
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($39.98 @ NCIX)
Total: $479.68 ($520-$45 rebate)
  • Quote people's post else they won't know you replied.
Crapware | 4670k | Hyper212X | GSkill RipjawsX 16GB | Sapphire R9 280x VaporX | 840EVO 120GB | 1TB BLACK + BLUE
Logitech G102 | Corsair K70 MX Brown | HyperX Cloud
https://linustechtips.com/topic/686014-upgrading-friends-system/#findComment-8810491
9 hours ago, The Non-Info Broker said:
would it actually be better to go with an i5 6500 instead, He is wondering because people are telling him the i5 6400 could bottleneck some gpus because of its clockspeed in some games.
Nobody's replying cuz you're not quoting their posts. People won't see you replied unless you do that.
Yes the 6500 would be a lot better, at least he'll see significant jump in performance.
And change that SAMA PSU to either of these:
http://www.newegg.ca/Product/Product.aspx?Item=N82E16817139147
http://www.newegg.ca/Product/Product.aspx?Item=N82E16817151094
https://linustechtips.com/topic/686014-upgrading-friends-system/#findComment-8815994
Yeah, I realized that after I made the post, anyways thanks he said he will switch for the 6500 and corsair CX-M thanks for the help.
https://linustechtips.com/topic/686014-upgrading-friends-system/#findComment-8816310
