5 minutes ago, jasonwj322a said:
Ive looked into Phillips Hue but those are super expensive. Any other just as good or similar with cheaper price tags?
How much are you trying to spend? NZXT has their Hue+ LED lighting kit which is pretty darn good. Lots of settings, lots of lights, extensions, etc. It's about $60 USD
https://linustechtips.com/topic/685244-best-led-strips/#findComment-8801590
I really dont want to spend too much, I dont necessarily have a set number. As long as the thing is worth the money im fine with it
https://linustechtips.com/topic/685244-best-led-strips/#findComment-8801624
ebay is your friend.
5m LED strip w/ controller, power supply and remote. Should be less than $20 for an RGB kit. @manikyath and myself (probably many more) use DongHangLo strips and so far we haven't set ourselves on fire
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
https://linustechtips.com/topic/685244-best-led-strips/#findComment-8801643
hey, mine's a boutique RGB strip from paul neuhaus :D
all the parts are from some company with shenzhen in the name, but combined it somehow is a made in germany product xD
https://linustechtips.com/topic/685244-best-led-strips/#findComment-8801673
25 minutes ago, ThioJoe said:
Do you need them to be wifi controlled? You can get cheap chinese ones off Amazon (they're all the same just rebranded) that are just controlled via a little remote.
Im aware of the ones you guys are talking about but I'm worried about their reliability.
https://linustechtips.com/topic/685244-best-led-strips/#findComment-8801783
i have over 800 hours on mine at this point and it's still up to spec on all colors
https://linustechtips.com/topic/685244-best-led-strips/#findComment-8801842
mine was branded aswell, still a shenzen kit.
https://linustechtips.com/topic/685244-best-led-strips/#findComment-8801865
1 hour ago, jasonwj322a said:
Can you link me yours?
It's a re-branded ChingChangChong kit I picked up in a supermarket. Can't even find a picture of it
FOUND IT! https://en.bva-auctions.com/auction/lot/19981/6928941
https://linustechtips.com/topic/685244-best-led-strips/#findComment-8802297
