Headset with no microphone
Solved by Spork829,
5 minutes ago, 8-Bit Ninja said:What you want is headphones, headsets are headphones with a mic built it. The audio technica m50x's are a good choice
Yep, those are a great choice. However I love my M40X's. If you want to save a little money and especially if you want portability (M40X's fold up while the M50X's don't) they are a great choice, as the two have basically the same sound quality.
