Did you verify that the skyrim process is not running in task manager before launching the game again?
CPU: Intel i7 - 5820k @ 4.5GHz, Cooler: Corsair H80i, Motherboard: MSI X99S Gaming 7, RAM: Corsair Vengeance LPX 32GB DDR4 2666MHz CL16,
GPU: ASUS GTX 980 Strix, Case: Corsair 900D, PSU: Corsair AX860i 860W, Keyboard: Logitech G19, Mouse: Corsair M95, Storage: Intel 730 Series 480GB SSD, WD 1.5TB Black
Display: BenQ XL2730Z 2560x1440 144Hz
https://linustechtips.com/topic/684987-need-help-steam/#findComment-8798631
5 minutes ago, Train27 said:
Have you tried the basics? Just to name a few:
  • Reboot your pc after any program installation.
  • Check for firewall blocks.
  • Check for antivirus blocks.
  • Check for cache integrity (steam feature)
  • Try to run with admin permissions.
  • Reinstall the game.
i just got my pc pretty much. is there a way you can tell me how to do that stuff, like in a skype? ill paypal you 5
https://linustechtips.com/topic/684987-need-help-steam/#findComment-8799255
Sorry but it's really late in my country, I should even be awake right now xD However, I'll try to guide you through the easy steps so that you don't get lost.
Okay, to it:
  • I suppose you do know how to restart your computer, in case you don't, it's usually another option right next to "Turn off" (that assuming you turn off your pc from the operating system and not from a physical button).
  • To check the game's integrity, fo to your steam library and right-click the game, then Properties > Local Files > Verify Integrity of Game Cache.
  • To reinstall the game, right click again on that game and choose "Delete local content", then click again the big blue "Install" button under the name of the game.
  • To run the game with administrator permissions, you'll have to find it in your files directory (usually wherever you have Steam installed > steamapps > Common > Skyrim), then right-click the .exe file and choose "Execute as administrator".
Hope it helps, reply if not.
https://linustechtips.com/topic/684987-need-help-steam/#findComment-8799291
