Power converter adaptors
rn8686
I am currently looking to buy a cheap 144 hz monitor on Newegg AU. I was looking at the specs sheet for the Acer GN246HL monitor, but I noticed that it had a "Type A" power plug used in North America. I am in Australia so it obviously wont work here, but I also found a cheap socket converter, the GENERIC PA-3515. Is this safe to use and are there alternatives if not?
Please quote our replys so we get a notification and can reply easily. Never cheap out on a PSU, or I will come to watch the fireworks.
PSU Tier List
My specs
PC:
CPU: Intel Core i5-6600K @4.8GHz
CPU Cooler: Noctua NH-U14S
Motherboard:  ASUS Maximus VIII Hero
GPU: Zotac AMP Extreme 1070 @ 2114Mhz
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400
Storage: Samsung 850 EVO-Series 500GB
Storage: Western Digital Caviar Blue 1TB
Case: Cooler Master MasterCase Pro 5
Power Supply: EVGA 750W G2
Peripherals
Keyboard: Corsair K70 LUX Browns
Mouse: Logitech G502
Headphones: Kingston HyperX Cloud Revolver
Monitor: U2713M @ 75Hz
The power brick for that monitor seems to have a standard iec 60320 c5 connector, so you can get a nema 5-15 to iec 60320 c5 cable and it will work fine
I looked it up there, but the only one sold has a NEMA 5-15 Power Plug which wont work here.
PSU Tier List
My specs
PC:
Peripherals
Where are you?
The nema 5-15 is what the US uses.
Thats what I mean, I need somthing for Australia.
PSU Tier List
My specs
PC:
Peripherals
3 minutes ago, Electronics Wizardy said:
Amazon doesnt ship that product here. Would that other power adaptor work? Do they sell any of those cables on Newegg AU (I cant find any)?
PSU Tier List
My specs
PC:
Peripherals
Power adapter would work fine. Just look for c-5 cable.
Thanks. Cant find any C5 cables there, ill use that power adaptor or try to find a cable in a store.
Edit: Found one on a store online here, thanks again.
PSU Tier List
My specs
PC:
Peripherals
1 minute ago, Naeaes said:
Can the monitor even run 230VAC@50Hz? US grid is 120VAC@60Hz.
I think so:
Power Supply
120 V AC / 230 V AC
PSU Tier List
My specs
PC:
Peripherals
