Will my rig bottleneck?
Go to solution Solved by i_build_nanosuits,
4 minutes ago, J0hN_TH3_P4P7T0 said:
- will my 1070 work with the cpu(amd phenom 2 x4 955(4 cores)) that i have right now?
- will there be any bottleneck if so how much?
- will the bottleneck damage my new gpu before i'm able to upgrade?
- Yes it will
- Yes, a tremendous amount...like...really really bad
- No, it will not damage anything...it will just run games like poop with low GPU loads and nowhere near the perf you should be getting.
Hello i recently bought a GTX 1070 Strix however i can not afford a cpu,mobo,ram ... right now to i'm planning to updrage them later on in blackfriday. will my 1070 work with the cpu(amd phenom 2 x4 955(4 cores)) that i have right now? will there be any bottleneck if so how much? or will the bottleneck damage my new gpu before i'm able to upgrade?
https://linustechtips.com/topic/683723-will-my-rig-bottleneck/
- Yes it will
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/683723-will-my-rig-bottleneck/#findComment-8784420
