hey guys, i have just been looking at new parts for my new pc, which will mostly be used for gaming.  so tell me if you guys see anything wrong with my current plan for my machine.
fractal design arc midi r2
msi gaming N780 3gb
SeaSonic X series x650 gold
g.skill ripjaws 8gb DDR3 1600
MSI Z87-G45 gaming
Intel i5 4670k
Noctua NH-D14
Western Digital WD Blue 1TB 7200RPM 64MB cache
any replies would be helpful.
https://linustechtips.com/topic/68328-help-with-new-gaming-machine/
Depending on your budget, if you can squeak in even just a 60GB SSD as your boot drive, that would make a major performance gain.
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
What's your budget?
My Pc: Cpu: I7 4790k @ 4,8 Ghz @1,25 volts, Motherboard: Maximus VII Formula, Graphicscard: 2x Titan X @1,4 at stock voltage (soon to be replaced), Ram: 32 gb Corsair Dominator Platinum 2133 Cl 9, SSD: 2x 850 Pro 1 Tb in Raid 0, 2x Samsung 840 Evo 1 tb raid 1,, PSU: Corsair HXi Series 1000W 80+ Platinum, Case: H440. Soon to be watercooled again, maybe, probably, the Titans are too loud.
What's your budget?
And where are you shopping?
NZXT Phantom windowed, Asus Z77 Sabertooth, Intel 2600K, Noctua NH-D14, EVGA 780 Classified, Crucial Ballistic Tactical, Crucial M4 128GB + Samsung 850 EVO, Corsair RM850, Creative X-Fi Fatal1ty Peripherals: Sennheiser HD598, FinalMouse Classic, SteelSeries Qck Heavy, Ducky Shine Zero (MX Brown), AOC G2460PF & Qnix QX2710
Build Log: Phantom - Antique Noctua
Considering the psu is veering on the side of overkill, I'm pretty sure the OP can get a cheaper one for the ssd.
Even his GPU is insane for the price. We need some answers here!
