Node 202 owners- strong enough panel for placing an LCD on top?
yenic
Considering this build, if the case is strong enough to sit horizontally and have my LCD on top of it. Anyone that owns this case, is it strong enough for this?
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($318.99 @ NCIX US)
CPU Cooler: Scythe BIG Shuriken 2 Rev. B 45.5 CFM Sleeve Bearing CPU Cooler  ($37.99 @ SuperBiiz)
Motherboard: Asus Z170I PRO GAMING Mini ITX LGA1151 Motherboard  ($160.99 @ SuperBiiz)
Memory: Crucial Ballistix Sport LT 32GB (2 x 16GB) DDR4-2400 Memory  ($169.99 @ Amazon)
Case: Fractal Design Node 202 HTPC Case  ($73.86 @ Amazon)
Power Supply: Corsair SF 600W 80+ Gold Certified Fully-Modular SFX Power Supply  ($119.99 @ Amazon)
Other: Samsung 960 EVO 1TB ($480.00)
Total: $1361.81
Generated by PCPartPicker 2016-10-29 18:53 EDT-0400
How heavy are we talking?
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
I don't own one (yet), but I can tell you just by looking at it that it should be able to hold at least 15 pounds no problem.
Main rig on profile
VAULT - File Server
Intel Core i5 11400 w/ Shadow Rock LP, 2x16GB SP GAMING 3200MHz CL16, ASUS PRIME Z590-A, 2x LSI 9211-8i, Fractal Define 7, 256GB Team MP33, 3x 6TB WD Red Pro (general storage), 3x 1TB Seagate Barracuda (dumping ground), 3x 8TB WD White-Label (Plex) (all 3 arrays in their respective Windows Parity storage spaces), Corsair RM750x, Windows 11 Education
Sleeper HP Pavilion A6137C
Intel Core i7 6700K @ 4.4GHz, 4x8GB G.SKILL Ares 1800MHz CL10, ASUS Z170M-E D3, 128GB Team MP33, 1TB Seagate Barracuda, 320GB Samsung Spinpoint (for video capture), MSI GTX 970 100ME, EVGA 650G1, Windows 10 Pro
Mac Mini (Late 2020)
Consoles: Softmodded 1.4 Xbox w/ 500GB HDD, Xbox 360 Elite 120GB Falcon, XB1X w/2TB MX500, Xbox Series X, PS1 1001, PS2 Slim 70000 w/ FreeMcBoot, PS4 Pro 7015B 1TB (retired), PS5 Digital, Nintendo Switch OLED, Nintendo Wii RVL-001 (black)
I do own the Node 202 and i would not do it. The shell is made entirely of plastic and will therefore not support that much weight. I would say maybe 2-3 kgs.
To RGB, or not to RGB? That is the question.
- Shakespeare. Hamlet, Act III, scene I.
Another guy that owned it said (randomly at PCPP) that the panels were solid steel, they're plastic?
Yes the panels are plastic, but the internal frame is aluminium (or some other metal).
17 minutes ago, yenic said:
Maybe 12lbs? Typical modern LED backlit LCD
http://www.dell.com/ed/business/p/dell-u2414h/pd
Don't do it. I wouldn't trust my Node 202 with 12lbs.
There's a metal plate beneath the top cover but I don't think it contacts anything besides the brace.
If you put a monitor on top. It might block the cooling of the CPU.
Also, the case doesn't support big air cooler. Small cooler will have difficulty to handle any overclocking of your 6700K. Is it a bit of a waste to use a K processor for this build?
Just want the 4Ghz stock. Not OCing, not a financially limited build. If I can't put my LCD on top (to save space), probably won't do it at all.
There are advantages to a K-series chip that go beyond overclocking.
You can't use the case vertically?
I see.
No GPU on the part list. Doesn't seem to be built for gaming.
No, I have 3 of those LCDs I linked on a fairly large desk. And a laptop+dock here too. I also use 2 mice (left and right hand side of my keyboard). No extra space and I don't want another tower or machine on the floor. There's barely space for my speakers.
That case looked like the best built horizontal case on the market that wasn't one of the massive Silverstone HTPC cases.
Just now, Deli said:
I see.
No GPU on the part list. Doesn't seem to be build for gaming.
GPU will probably be GF1060 6GB with blower style cooling. Was undecided on 1060 vs other options there.
Have you looked at some monitor trees? Mount-it makes one that attaches to the desk if you're willing to shop for a bolt at your hardware store.
Please go with blower cooling. I'm glad someone knows their coolers.
Monitor arm is another option, I wish someone made a sturdy desktop-style case (that isn't horrendously ugly) still so I had both options. I guess I'm still stuck in the 80s but sitting your monitor on your case makes some sense and I don't think there's even a choice to do that now.
Since you have three of the same the tree will help keep them level. DIYPC makes a good metal case but it's about the size of a Betamax.
I have custom stands for them right now, was planning on looking at the arm idea down the road when I moved to a standing desk.
It doesn't sound like anyone has any faith in using the Node202 this way, so I'll go with my plan b here. Which was the Skull Canyon NUC which will fit my needs mounted on the back of my LCD. Thanks everyone. If anyone has more info on the Node feel free to chime in. I knew it was borderline on being able to hold an LCD, is a shame.
I'll see if it can handle the weight once I get home.
That will be very interesting to hear, though the fact there's a metal plate behind a plastic shell doesn't sound good. I thought those were solid steel panels all around, those molded plastic edges should bend a lot over time. Though that metal brace in the middle might make up the difference (that was always my hope with the 202) if they were plastic as reported here.
I never thought I'd miss the days when cases were weapons.
I weighed an extra Asus 27" LED backlit LCD I had sitting here unused, weighs 5.1kg (11.2lb). I think this is going to be ballpark for my 24" with the stand I'm using. I stand by my original 12lb estimate.
I weighed my LG 22MP55 and no issues but it feels like 6lbs.
I weighed my LG 34" ultrawide and no issues and I think it weighs 15lbs.
No flex (or possible flex over time) with the 34"? I would not likely ever use anything larger than my 27" Asus so I think your ultrawide is a good worst-case scenario.
