Should have those. Some screw threads look similar, but are actually different. So check again or see manual if it mentiones the added screws you need.
The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane.
Basic PC parts guide
PSU Tier list
https://linustechtips.com/topic/682296-help/#findComment-8771808
Could be because of the I/O shield pushing the mobo back a bit. A few milimeters is no prob. But be sure that the standoff are in the actuall correct places then for your mobo size (ATX)
PSU Tier list
https://linustechtips.com/topic/682296-help/#findComment-8773498
If there is a splitter type connection you can use that, because your probably connect that to the CPU fan header on the Asus mobo.
So AIO fan headers > Splitter cable, Y cable or wahtever the name they have given it > CPU fan header mobo. Don't forget that the splitter might also have a molex connection for power.
PSU Tier list
https://linustechtips.com/topic/682296-help/#findComment-8776303
6 minutes ago, MatchuEnsmith said:
I did a fresh install and I have 16gb of ram, a Samsung 850 evo, and an Intel i5 6600K. A simple 32mb download took 15 minutes... I have all the drivers so what could it be???
download depends on internet speed.
That talks about your internet not your computer
Shipping sucks
https://linustechtips.com/topic/682296-help/#findComment-8779961
Asume windows 10. So could be updates downloading. What is taskmanager saying about internet usage? And what processes use bandwith?
Wired connection or wireless?
PSU Tier list
https://linustechtips.com/topic/682296-help/#findComment-8780997
3 minutes ago, MatchuEnsmith said:
I have an Ethernet connection and so far windows has not asked to update yet. What drivers would I need to install?
Have you formatted your hdd and ssd? If they are brand new you wont be able to actually use them until you do that through Computer Management-->Storage-->Disk Management.
CPU — AMD Ryzen 7800X3D
GPU — AMD RX 7900 XTX - XFX Speedster Merc 310 Black Edition - 24GB GDDR6
Monitor — Acer Predator XB271HU - 2560x1440 165Hz IPS 4ms
CPU Cooler — Noctua NH-D15
Motherboard — Gigabyte B650 GAMING X AX V2
Memory — 32GB G.Skill Flare X5 - 6000mHz CL32
Storage — WD Black - 2TB HDD
        — Seagate SkyHawk - 2TB HDD
        — Samsung 850 EVO - 250GB SSD
        — WD Blue - 500GB M.2 SSD
        — Samsung 990 PRO w/HS - 4TB M.2 SSD
Case — Fractal Design Define R6 TG
PSU — EVGA SuperNOVA G3 - 850W 80+ Gold
Case Fans — 2(120mm) Noctua NF-F12 PWM - exhaust
          — 3(140mm) Noctua NF-A14 PWM - intake
Keyboard — Max Keyboard TKL Blackbird - Cherry MX blue switches - Red Backlighting
Mouse — Logitech G PRO X
Headphones — Sennheiser HD600
Extras — Glorious PC Gaming Race - Mouse Wrist Rest
       — Glorious PC Gaming Race - XXL Extended Mouse Pad - 36" x 18"
       — Max Keyboard Flacon-20 keypad - Cherry MX blue switches
https://linustechtips.com/topic/682296-help/#findComment-8781307
Start-->Settings-->Updates and Security-->(top on the left) Windows update-->(grey box) check updates
https://linustechtips.com/topic/682296-help/#findComment-8781322
Windows 10 updates automatically. So you have no option there if it starts downloading in the background. Also it installs some basic drivers, but for latest you should go to manufactors website for mobo and GPU.
Also what about the usage? And have you done speedtest? speedtest.net
PSU Tier list
https://linustechtips.com/topic/682296-help/#findComment-8781736
