My S3's power button is broken... its super sensitive and the slightest vibration make it go off.
I asked verizon for a replacement. theyre sending it. but when i have to return the device i need to get rid of cyanogenmod. but i cant get into clock work recovery because of that fucking power button.
even if use an app and click the option "boot into recovery" the vibration from the phone makes the power button activate and then it turns itself off. this is pissing me off... solutions?
Fractal Design Define R4 | MSI x79a-GD45 | 3960X @ 4.6Ghz | Lots of EK Blocks | EVGA GTX780Ti 3GB | Corsair Dominator Platinum 16GB (4x4) DDR3 1866 | Samsung 840 Pro 512GB SSD | Western Digital Red 2TB x4 (Raid 10) | Corsair AX760 | Windows 7 Professional 64-bit
https://linustechtips.com/topic/68214-s3-broken-help-please/
Look up a s3 rom with flash reset
https://linustechtips.com/topic/68214-s3-broken-help-please/#findComment-939893
I know how to flash things. I know exactly what to do to fix my phone IF my power button wasn't broken. I can't do anything on my phone. My power button doesn't work. I tried to flash stock on and the power button acted up as i started SO there is no OS on my phone. I can access stock BIOS options BUT i cannot do anything else. IT says "samsung" and doesnt go any further. No os installed on it. I'm just gonna send it into tech support and tell them i just followed phone instructions.
https://linustechtips.com/topic/68214-s3-broken-help-please/#findComment-951038
If you have adb access then just re flash the default rom through that.
http://forum.xda-developers.com/showthread.php?t=1645143
▶ Learn from yesterday, live for today, hope for tomorrow. The important thing is not to stop questioning. - Einstein◀
Please remember to mark a thread as solved if your issue has been fixed, it helps other who may stumble across the thread at a later point in time.
https://linustechtips.com/topic/68214-s3-broken-help-please/#findComment-951357
EDIT
nvm
use adb !
If your grave doesn't say "rest in peace" on it You are automatically drafted into the skeleton war.
https://linustechtips.com/topic/68214-s3-broken-help-please/#findComment-951375
