Dafuq did I just read?
"Say it, do it, preach it, shout it, but never, absolutely never, believe your own bullshit"
Credited with the whole female avatar trend
Your thoughts here http://linustechtips.com/main/topic/67178-your-top-three/
https://linustechtips.com/topic/68151-help/#findComment-933146
I like the color scheme of Noctua fans. Deal with it. Forget about the bad memories of the past.
"wunder you really are as straight as a rainbow" - Lanoi "can I fisterino your nose" - WunderWuffle
Forget about the bad memories of the past, take the good ones along with you through the present, and look forwards to the good things that will come in the future.
https://linustechtips.com/topic/68151-help/#findComment-933150
You day going well then is it?
Objective- Key retrieval
Required tools:
Latex gloves
Leather gloves
Hammer
Hedge Clippers/scissors
x2 Extendable Grabbers
Required Materials:
x2 Buckets
Bleach
Alcohol 91% or better
Blowtorch
Steps
1. Use hammer, incapacitate key thief (use of lethal or non lethal force to be determined by end user)
2. Use hedge clippers/scissors to remove pants of key thief
3. Put on latex gloves, move genitals with first extendable grabber, retrieve keys with second extendable grabber.
4. Place keys in bucket, pour in non-diluted bleach, let soak for one hour.
5. Put on Leather gloves, retrieve keys from bucket with grabber and use blowtorch to dry.
6. Fill second bucket with alcohol, dip keys (while still hot) into the alcohol to cool
7. Heat keys with blowtorch then dip into the bleach in the first bucket to cool
8. Repeat steps 6 and 7 as many times as desired.
9. Take the keys of the offending person and defecate on them
10. Go about your business
Alternative option- Retrieve keys, hand sanitizer, grow up, refrain from asking for help with situations like this on the Linus Tech Tips forum
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/68151-help/#findComment-933228
Required tools:
Latex gloves
Leather gloves
Hammer
Required Materials:
x2 Buckets
Bleach
Blowtorch
Steps
i liked your first solution better
and its off topic so.....
https://linustechtips.com/topic/68151-help/#findComment-933234
Call no homo (or full homo idc) and use your teeth like a man.
Then stare the kid in the eye and wink.
Walk away with keys in mouth
Big Bertha3570k @ 4.5GhzASRock Fatal1ty Z777970 DCUII TOP EVGA GTX 780Swiftech H220 w/ NF-F1216GB RAM128GB Kingston HyperX 3K1TB Western Digital Black40GB Western Digital Raptor 10K PeripheralsMionix 3200 MouseCMStorm Quickfire Rapid w/ Cherry MX Blues2 x Dell U2713HM AudioAsus ROG Orion Pro HeadsetSony XB-500AKG K240Bose AE2i​Fiio E10
Samsung Galaxy S45.0" 1920x1080p Super AMOLED screen16GB Storage2600 mAh battery1.9Ghz quad-core Krait CPU2GB RAMCyanogenMod CameraNikon D310018x55mm NIKKOR VR Lens14.2 MP
https://linustechtips.com/topic/68151-help/#findComment-933254
Ive now taken his laptop, Im hoping he will trade my keys for his laprop
Set his homepage to gay pr0n
https://linustechtips.com/topic/68151-help/#findComment-933283
just shove your hand down there and get your keys. then knock the guy out.
oh wait are you going for a non invasive and non violent way? I'm the wrong guy to ask :P
Rig 1 CPU: 3570K Motherboard: V Gene GPU: Power Color r9 280x at 1.35GHZ  RAM: 16 GB 1600mhz PSU: Cougar CMX 700W Storage: 1x Plexor M5S 256GB 1x 1TB HDD 1x 3TB GREEN HDD Case: Coolermaster HAFXB Cooling: Intel Watercooler
"My day so far, I've fixed 4 computers and caught a dog. Australian Tech Industry is weird."
"It's bent so far to the right, It's a hook."
https://linustechtips.com/topic/68151-help/#findComment-933285
