This video says it all...  will google ever learn how to make their phones as fast as an iphone.  I phones have much superior gaming performance, multitasking, and are overall more powerful.  I would gladly switch from my gs7e but other than performance, my Samsung is better in every way I can think of.
Overall I really wish that Google would just learn to optimise their os for better performance.
https://linustechtips.com/topic/681110-will-android-ever-learn/
Well you can't have both.
Either you settle for great OS optimisation ---> Apple
or you get android phone that you can adjust however you like
I was using cheap android devices at first, then switched to iphone 4S, and later to iphone 5s. Then I went to galaxy s6, and from there I went back to iPhone SE. Same as iphone 5s but a bit better components inside.
When it comes to phones, I'm iPhone fan all the way :P
But when it comes to Mac vs PC ... well PC it is :P
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/681110-will-android-ever-learn/#findComment-8758340
optimizing is hard to do when you have 20+ different chipsets and any number more different cpus of various performance all running a single os. apple can do it well because they have a closed environment and only have to develop for just one or two cpus in set configurations.
Altair - Firestrike: http://www.3dmark.com/3dm/13945459
CPU:  i7-4790 @ 3.6 GHz Motherboard: Gigabyte B85M-DS3H-A RAM: 16GB @ 1600MHz CL11 GPU: XFX RX 470 RS Storage: ADATA SP550 240GB | WD Blue 1TB | Toshiba 2TB PSU: EVGA B2 750W Case: Phanteks Enthoo Pro Fans: Phanteks PH-F200SP (Front) | Phanteks PH-F140SP (Rear) | Noctua NF-A15 (Top)
Mouse: Logitech G502 | Keyboard: Corsair K70 MX Brown | Audio: Sennheiser HD 558
https://linustechtips.com/topic/681110-will-android-ever-learn/#findComment-8758341
I'm not going to rubbish each product but i will rubbish the speed test. some of those apps have network requirements before they start. its far from comprehensive to perform a speed test the way they did.
Again I'm not disputing that the new iPhone is faster then pixel. Apple is leading mobile processor development.
ψ ︿_____︿_ψ_
https://linustechtips.com/topic/681110-will-android-ever-learn/#findComment-8758373
They should at least optimize it for their Nexus lineup :P
https://linustechtips.com/topic/681110-will-android-ever-learn/#findComment-8760058
